Hey yall,
I went to check my ignition timing when i was under the hood yesterday. I noticed the BTDC marks on the pulley were off to the driver side from the indicator arrow. Far enough off that no marks were lined with the arrow, but close enough that I could still see almost all the marks.
What could cause the marks to be that far off? Maybe the engine wasn't fully up to temp?
Does the timing belt have anything to do with the ignition timing? I had the timing belt done at a shop a few months ago. Since then, I have had a few rare occurrences where I go to start the engine and the check engine light comes on immediately and knocking sounds like it is coming from the engine. I immediately turn off and attempt to start it a few minutes later and it runs fine like nothing happened.
The dizzy cap looks like it is sitting pretty advanced from what I remember setting it when I replaced the dizzy 6 months ago. I've got more smoke than I think I should be having and it smells like it is burning rich. It is seems like it is burning through fuel.
I replaced my spark plugs yesterday. The coloration of the plugs looked fine but they all seemed to be wet, which would indicate burning rich, correct?
I had the intake manifold off yesterday to replace the injectors with reman ones. Sadly the reman ones looked really beat up from the shipping and some had torn filters. I decided not to install them and will send them back. None of my current injectors seems to be leaking so I'll just leave them alone for another few months or year until I really need to swap them out.
I am reading up on checking TDC on #1 spark plug before setting ignition timing but feel a little confused on how to do it if anyone is willing to attach a good youtube link or write out the process.
As always, thank you all for your time and experience.
