Hey everyone!
I'm new to this forum but since I started getting interested in buying a Pathfinder I found this place and have been reading a lot of threads and learning a whole bunch.
A few months ago I bought a 2002 Pathfinder and I love it, it's been looked after so well and has very few, small issues to fix.
One of those issues was that after the AC has been on for a long time, it will spill out on the passenger side onto the carpet (most commonly when I make a sharp left hand turn). I've read a handful of threads here of people having the same issue and I was looking for the drainage pipe to be able to see if that was blocked. I've pulled out the glove compartment and the backing and found the AC unit itself but no pipe.
What I do see is this big black box with a small radiator inside, which I assume is for cooling/heating the air to pump into the inside of the car? Inside there is also some old leaf litter.
When unscrewing it, I noticed that the foam seal on the right side that connects to the white housing was soaking wet and you cal also see a stream of water on the floor so I'm lead to believe that there is some kind of blockage that is causing the lower half of the black box to fill with water and eventually overflow.
I lifted up the carpet and found that it was heavily flooded with water and had even made it's way behind the passenger seat to the rear seats. I was able to drain the majority of the water out with a rubber seal under the car.
My issue is, that I don't know how to get the bottom half of the box out to access the radiator/leaf litter or if that is even the issue at all. The threads I saw here talk about drain pipes and I'm not sure if I'm having the same issue or not?
Thanks a lot in advance everyone!
