Tank95
    Solid axel swapped
    Screwdriver Mechanic
    XE
    Maryland
Tank95's Achievements
  1. I have the same problem. However I've looked up and down and it does not look like it's coming from the oil pressure sensor. I did install a t fitting for the oil pressure sensor with an additional Gage so I could actually monitor the pressure by numbers. But it doesn't look like it's coming from there. It's also not a head or valve cover. Could it be spraying up from the oil pan? Is there anywhere else it could be coming from on that side of the motor?
