PartTime4WD last won the day on March 4 2020
PartTime4WD had the most liked content!
04 SE
Skilled/Experienced Mechanic
30-35
2004
Indiana
Country
PartTime4WD's Achievements
I ended up getting some avm 761s. They gave been great so far. Solid exterior construction. Super durable. Pricey at $160 though.
Sorry about the delay. After settling with stock front and 9447 in rear I have about 6 inches in the back and about 3.75 in the front.
Couldn't wait. Got the rear on. Jesus the rake is huge. Handles a lot stiffer but damn the flex is nice.
Got mine in about 2 days. Now just gotta find the time to put this altogether. AC and 9447s
Rockauto had the gr2s for only $30 a strut so I got 2 but I still plan on reusing the old struts and then I'll just be ready in about 50k miles once I get another set of bearings and mounts. Then I need to fab up a missing link and get my locker in the front once I get it. Then I should be good for a year or 2. How long did it take for you to receive your AC coils?
Ordered some AC springs for the front. Plan is to swap the springs into my current struts and use all existing hardware and just replace springs. Might need camber bolts so I'll order those also and return if not needed. With only about 36k on the odometer I know the struts have some life left even though they are 16 years old at this point. Hoping to get to 80k before upgrading struts and mounts. Crazy 4x4parts charges $60 for shipping where as LRDirect only charges $40 and is coming from the UK and arrived in 4 days.
How do you feel about the ome springs vs the AC springs. Everything else I'm settled on but the springs themselves I'm not sure where the best place to get them is from or which would be best. To be completely honest this is my daily driver so it's gonna be on pavement or dirt roads 90% of the time and off road around here is mainly sand and mud.
You did a 2 inch AC lift right? What parts did you go with? I'm trying to nail it all down. I wanna do 2inch ac springs, kyb struts and best to use Nissan mounts and bearings correct? Will I need camber bolts also? Thanks for all the help btw.
Awesome thanks for the tips. The only reason I want to put the rear in now is my ass end bottoms out really easy and it's touched the fenders twice so don't wanna rip anything off. Hits the bump stops pretty easily. I guess I can always pull them back out if it's too much of a rake.
So ordered some 9447 springs and some pro comp 326500 es3000 shocks for the rear. Anything I should be aware of before throwing it all in? Hopefully the take isn't too crazy cuz I won't get to the front for a while.
Yikes I'll remember that. If I need pulled out from the front what would be the best point to do it? Just get a hitch d ring and do it from the rear instead? Planning on doing a custom bumper at some point but caution would be good until then. Thanks for the heads up!
Big weekend for me. Got the light bar mounted on the rack. No glare at all with how far back it is. Not a bit of light hits the hood. Ran the wiring down the rain stripping. Just pulled the rubber back on the a pillar and tucked it in there. Also got the amp and CB hooked up. Had to modify the Firestik mount a bit to get it to sit right with the cable I had. All wires go through an existing hole in the firewall where the wiring comes in. Just pushed the gasket towards the engine and cut a small line in it for my wires to pass through then pulled it back in. Also got my receiver installed and mounted my bumper light bar inside the first hole in the bumper. Previously I had it mounted to the front license plate bracket but this is much sturdier. Not sure about the best way to post pictures so here is the direct link for better quality. https://imgur.com/a/3M8Z1OR https://imgur.com/a/xTqLtX2
Wheel spacers and roof rack on today also.
Hub update. Got my replacement ones in and it appears the bearing on the hub failed. Swapped it out and greased it up with some better grease than what it came with and the noise is gone and locks and unlocks fine. The noise was like hitting the rumble strips and more of a growl and went away when i locked them because that bearing stopped moving when the hub was engaged. Now as soon as my Lokka comes in I'm ready to go.
I almost bought those myself. I put Kuhmo Road Venture AT51s on mine. Yours would be about an inch taller than my 245/75r16. I'll probably end up messaging you about a year from now to see how they handle if I want to make a switch. Its snowing in Indiana right now and they seem ok. Not as good as the Cooper Discoverer M+S i had on my last vehicle but it could also be that that was front wheel drive and the pathy is rear wheel.
