Gmar11
Gmar11 last won the day on April 15 2021
Gmar11 had the most liked content!
Stock
Skilled/Experienced Mechanic
Choose
2000
Dallas
Gmar11's Achievements
AC front springs, 9447 rears, billstein shocks Sent from my iPhone using Tapatalk
Selling the pathfinder soon fellas, still looks great for a 20 year old vehicle though. Sent from my iPhone using Tapatalk
@Slartibartfast Thanks! My truck didn't come with any manuals from the PO, I believe he got it from an auction because there was still the auction tags on the key ring he gave me. It didn't start leaking until I pressure washed the @!*% out of the roof from all the tree sap we get here in Texas. I don't think it'll leak again, I did a pretty good job with the silicone install so hopefully all is well. If it leaks I'll just throw some flex seal on it, this is my wheeling/camping truck so I kind of abuse it.
Hey everyone, my sunroof is pissing water all over the interior. It's likely the drainage holes but the previous owner destroyed the sunroof and it only tilts so I cannot get to the drainage holes. I never use the sunroof and don't particularly care to chase down parts and take it all apart etc etc so I'm going to just silicone seal the sunroof. My question mainly is, does anyone know where the sunroof relay/fuses are so I can permanently mechanically stop the sunroof from opening after I seal this bad boy off? I was thinking there is probably a switch i can disconnect under the over head console. BONUS: Also same question for the cars antenna, I never use it and just bluetooth music but as soon as I turn the radio on the antenna comes up and looks very 1980s.
Thanks man! And no wheel spacers, just 4.5in back spacing method wheels. I took the front mud flaps off and I did some trimming on the inner fender well plastic. Sent from my iPhone using Tapatalk
Thanks man! No sir, I suppose the spare tire might add weight. I’m keeping it on just to fill up the visual gap under the bumper. I also think the 33in tire really helps fill the wheel well gap, there’s a slight rake and I was pretty worried but it turned out pretty good! Sent from my iPhone using Tapatalk
Got my LR9447 and AC spring lift installed. Bilstein shocks in the rear, SC creation control arm brace. KYG struts in the front. 285/75r16 tires. Sent from my iPhone using Tapatalk
Awesome! Thanks for the reply and all the information. I’m having everything installed today! Should be done by Friday because my shop couldn’t get all four tires today Sent from my iPhone using Tapatalk
Yeah the statement on the website confused me but now I can't seem to find where it used to say I needed wheels with 3.75" backspacing, I actually used your exact suspension setup as a guide to mine aside from choosing the 9447 rear coils. After having the lift installed I plan to go up to a 285/75/16 with the stock 16 inch wheels if possible. I don't mind going to a 15 inch wheel either, 33s will look more meaty on 15s. My last pathfinder i fit that same tire with just a sc spacer lift so I'm a little confused on which wheels will work.
Hey guys, any idea on the backspacing on the stock 16 inch wheels on the 2000-2001 pathfinder? Installing the front AC springs and KYB struts soon and need to know if I need to buy a wheel spacers to have clearance on the AC springs. Thanks in advance.
Hey everyone, bought all my parts for my lift for my 2000 SE. So far I've ordered and received: AC front coils KYB Excel front struts LR9447 I just need to buy rear shocks, what shocks does everyone recommend? Obviously Bilstein is the best but it seems everyone is running different series of shocks and wanted to see what the most common used is. Also, how likely is a severe rake with my suspension set up? Thanks guys!
Do the LR9447 springs have a potential for rake with the AC parts front springs?
