My 2002 pathfinder SE 4x4 has a very strange starting problem. So far I have replaced the fuel pump, fuel pressure regulator, fuel filter and installed a check valve. Here is what happens, I start the car, and it won't fire up, sometimes if I crank it long enough, 10 seconds for longer several times, it'll fire up, and other times it won't, no matter how much it's cranked. And when this happens, I notice that the car has been parked in an incline, with the front of the car uphill. Every time the problem occurs, car is found this inclined position.
But parking in this front up incline position doesn't always produce the problem, I have experimented. And the degree of incline doesn't have to be much, just a few degrees. I have so far, maybe 10 to 15 times, been able to start the car with starting fluid. But there's a further mystery which I can't figure out. Every time I start it with the starting fluid, it makes a sustained very loud noise, maybe 3 to 5 seconds, of a very high-pitched metallic rubbing sound. This sound never happens when not started with the starting fluid.
Not starting problem can occur as short as 1.5 hours if parked in an incline. It actually happened at a Walmart.
Any hints or suggestions will be appreciated.
Thanks
