bomberman
94 pathy se
Do Not Go Off-Road
1994
Gender
edmonton
bomberman's Achievements
i will be doing toe same swap but i lucked out and found a pathy with only 156000 kms on it but the frame is completely rotted out so im going to pull the standard and put it into my other truck nothing beats having the donor vehicle for reference
oh man im gonna have to order some
all the lights work if i start the truck with the remote start but when i touch the brakes the interior and the tail lights shut off
headlights do work both running lights and the when i turn the switch
hey guys i have a bit of an electrical problem which is my rear driving lighs dont work and my dash lights dont come on anymore but the funny part is if i use my remote start the lights are all on until i touch my brakes then everything shuts off also my horn no longer works
so i thought about doing a swap from auto to standard but i dont think my trans will hold out the long. also i have decided to stay with the auto. so my questions are my auto will sometimes not shift out of first so i talked to a place about getting it rebuilt they said it may be electrical is that possible also my trans gets warm i can smell it when i get out of the truck i dont have a tranny cooler but it still should not get that warm so i found a used trans for 650 bucks or they said that worst case it could cost 2000 -2600 so any help would be great
mine did the same thing everything worked power wise and there was no click in the started so i replaced the started and everything works fine now
i can send you one via text if you want
i have a black 94 parts truck sitting in my yard but i would like to replace it so it doesnt get completly rained out
Exhaust manifold bolt busted? Need a head job?
bomberman replied to Xmas's topic in 90-95 WD21 Pathfinders
have any of you guys tried a reverse helix drill bit on them? -
out by that little town of robb? i have done some camping out there
looks like there split open in a few spots nothing to major if you can weld and im in millwoods have you by any chance checked out the alberta safari park
the step bars are in rough shape but there yours if you want them also with my truck i have the jgc lift sitting in my trunk that needs to go in plus my auto is slipping bad so im going to do an auto to standard swap on it
