MTGunner
MTGunner last won the day on December 24 2019
MTGunner had the most liked content!
    2000 Nissan Pathfinder SE
    NW Montana
MTGunner's Achievements
NPORA Veteran (3/5)
25
  1. OK, answered my own question. Pulled the rear sway bar assembly apart. Links are junk. Ordered new. So, will get new bushings and links. Guess I will be looking at front links soon. BTW, you cannot believe how much dirt and gravel I vacuumed out. But, this is an Arizona car and very little rust. All came apart easily. After the front bar links need to chase oil leak. Hope to hell not a rear main seal. Only drips a drop each time. Engine uses VERY little oil. I check frequently. 180,000 miles plus. Ya’ know, I have a 2023 Tacoma P/U that is better on fuel, good power and lots of creature comfort. But, I love my 2000 Pathfinder. It’s a beast. MTG
  2. Is it necessary to replace rear suspension link ends if not worn? MTG
  3. Crawled up under rear suspension to find sway bar link ends OK. Will have to replace bushings and drive. Four link and panhard bar are secure. Shocks good. Springs good. Muffler good. So, ????? MTG
  4. Removed rear sway bar bushings to find they are worn. Guessing I need to replace link ends also. Cannot remove nut from right rear link end. Suggestions? MTG
  5. Shattered sun roof. Where to find a replacement? Has anyone replaced this glass and how difficult? MTG
  6. On the low setting my headlights really suck. I tend to run them on high beams. Anyone else have this problem? MTG
  7. Has anyone added a Timbren system to their Pathfinder? MTG
  8. Have driven this Pathfinder for 15 months now with no problems.
  9. Could someone post a simple color coded driver side mirror wiring diagram for a 2000 Pathy SE? Purchased a replacement mirror from Rockauto. Wiring connector from Rockauto is a one piece connector, but existing are two connectors in the door. Thanks for the help. MTG
  10. OK, have gleaned what has been offered. Thank you all. At this point I will look for a reasonably priced rear bumper cover with or without all cutouts. Can do myself. MTG
  11. Just looked at fleabay. Much more expensive than Rockauto or Partsgeek. Besides, have no PayPal account and have done no business on fleabay due to prices in the past. MTG
