6spdhlsd
    1996 SE 5spd
    Screwdriver Mechanic
    Choose
    Choose
6spdhlsd's Achievements
  1. Thanks for the help. I did find a very corroded ground under the driver's kick panel and I will relocate that. It sort of looks like that top left pic insert in the FSM. I also had to replace the link between the the motor and the arm links as well because it kept popping off. I managed to also duplicate the problem. Every time I turn on either the front or rear wipers they go dead with the compass and temp gauge for a while. My emrgency setup has a awitch, relay and a 15 amp fuse that I can power the front motor as needed.
  2. It just hapenned 2 weeks ago once and today. Haven't installed anything. I have a temp emergency setup with a switch, fuse and relay to operate the wiper motor.
  3. It's intermittent. It happed this morning again. As I was driving arround the wipers and console cam back to life.
  4. The whole console is dead. It was intermittently working today.
  5. I have the same problem with a twist. My front wiper does not work either.
  6. I am wandering what kind of experience do you have that led you to the analisys and conclusions above? FYI the unit of measure for force is lbs or lb (pounds). PSI = pounds per square inch is the unit for stress. If the bolt in question sees 3570 psi of stress you have a huge safety factor since a grade 8 bolt has a yield strength of 120,000 psi.
  7. Hi. I have a 1996 Pathy that is in need of exhaust. I need a resonably priced exhaust shop or parts supplier in South Western Ontario. I live an hour west of Toronto. Thanks.
