Baker95pathy
About Baker95pathy
  • Birthday 06/08/1984
    95 nissan pathfinder
    XE
    Tennessee
Baker95pathy's Achievements
  1. The switch is off and when I turn it on it runs higher rpms
  2. Yes overdrive is working. It shifts through every gear fine .
  3. I think I have a bent valve or more than 1. I'm ganna check compression to be sure but probably ganna get knew heads. But should I rebuild the ones I have or get new or get some off of a wrecked junker.
  4. I think I have a bent valve or more than 1. I'm ganna check compression to be sure but probably ganna get knew heads. But should I rebuild the ones I have or get new or get some off of a wrecked junker.
  5. Ok well I turned the engine about 10 to 12 times by hand and my marks on the belt and the gears are different every time. Shouldn't they line back up after a few rounds.
  6. Ok well I turned the engine about 10 to 12 times by hand and my marks on the belt and the gears are different every time. Shouldn't they line back up after a few rounds.
  7. Ok all timing is correct but it still won't start. It will almost start but then it just starts turning slow again. Still has a little back fire but no flame out the breather anymore. I'm stuck.
  8. Ok all timing is correct but it still won't start. It will almost start but then it just starts turning slow again. Still has a little back fire but no flame out the breather anymore. I'm stuck.
  9. Ok I counted the teeth on the belt and I was 1 off on top fixed that. Now I'm ganna check the ignition timing again to see where I'm at.
  10. Should the cams be hard to turn. My crank is a little tough to turn but that's normal what about the cams.
  11. Should the cams be hard to turn. My crank is a little tough to turn but that's normal what about the cams.
  12. Ok I do not have a way to test compression but when I try to start it with the breather off it occasionally blows a flame out the breather.
  13. I just bought a 95 nissan pathfinder. It has set for 4 months. The guy said he the timing belt broke he replaced it but it would not start. I checked and the timing was not set correctly. I set it correctly but it still won't start. The engine seems to be turning slow to me. I'm getting fire and I'm pretty sure I'm getting fuel because when I pulled out a plug it smelled like gas. Can someone please help me.
