Shaunna
    I just bought my pathfinder in phoenix and while driving home, it has that wobble, I found out that it is the rear control arms, ordered both upper and lower but it stalled about 70 miles from havasu. The elevation drop is only 300 feet but I was told it might be vapor lock. It is a 1997 2 wheel. Doing some research on how to fix vapor lock, it said to get a thermo spacer for the carb, also wrap fuel line in aluminum foil or change out mechanical fuel pump to an automatic fuel pump. Has anyone else gone threw this where the vehicle stalls while driving then wont sart again?
    Other/Unknown
    Female
    AZ
  • Interests
    Spending time with family and friends, camping, off roading, boating, shooting pool
Shaunna's Achievements
  1. I just bought a 1997 pathfinder in phoenix az. I was wondering if you think this sounds like vapor lock. Drove about 130 miles no problems except for the wobble, scary but found out that it the rear upper and lower control arms, those are ordered, but after about 130 miles it just stalled while going down the road, put into neutral and was able to start again, did this twice, then wouldnt start at all. Sat on the side of the road for about 1 hour and then it started drove another 20 or so miles and it stalled. This time wouldnt start. I left on the side of the road and went home.Came back the next day, it started right up drove about 5 miles it stalled and wouldnt start again. We towed it into parker, and checked out the fuses and just tried to trouble shoot stuff and nothing, so we were getting ready to pull home decided to try one more time, it started, made it 40 miles and stalled, pulled it home the rest of the way, next day it wouldnt start, went out the following day and it started. I has since sat in my driveway and I am trying to find out what it might be, I dont have a lot of money to just go out and buy parts to see if that fixes the problem. Hooked and obd11 and got codes p0325,p0180,p0120,p0443,p1705,p1447,p0171,p0443,p0120p,p0180p,p0325p. Any suggestions would be much appreciated. Thank you
