New to the forum and am stalled in a diesel conversion....
I have transplanted a td27 turcpbodiesel from a jdm 1992 nissan caravan into a 1994 hardbody kingcab 4x4. US model, originally V6 automatic.
Engine is in, runs excellent, and vehicle drives.....BUT transmission woes..does not shift, stuck in fail mode.. The diesel tcm has 2 connectors, and 36 pins, while the 94 truck has a single connector with 48? pins. Many many of the wires are different colors between the harnesses
I have the wiring diagram for the US truck TCU, but i have searched the friggin WORLD for a pinout diagram for a 1992 JDM caravan td27 automatic. No luck at all....With both wiring diagrams this would be easy....not so easy given the possible permutations without a guide.
SOOOOOOO.....I need one of three things....
A) A wiring diagram forva 1992 caravan TCU td27 auto
Or...
a definitive answer....can an automatic from a 1990-94 4 cylinder (non electronic) be made to work wiyh no tcu or engine connections? I assume a mechanical kickdown for this unit? Yes/no?
Or
C) switch to manual trans, in which case i need a bellhousing and clutch/flywheel for a td27 or td 25. I can easlily source the rest of the parts for this conversion here in Canada., but these items would have to come from abroad....any leads?..
Any help/guidance would be gratefully received. Thanks, edward
