kg03
Everything posted by kg03
  1. I too have the same situation as fueler and I am wondering how I can get the temperture out of the vents around 40 degrees. Running down the interstate I still get about 50 degrees out of the vents. Does anyone know if we can convert our systems to r-12 if one could get his hands on it. I know it ran at colder temps ( I had a 76 cutlass that would blow frost) just to get colder air out the vents. I know our vehicles are not the strongest in the industry as far as ac is concerned but I would like to be able to ride in the car for an hour straight without sweating.
  2. Hi all, faily new and i believe my first post. I am interested in lifting my QX4 up to the 2 inches offered by AC. It is my understanding that the ac coils are the same height just a higher spring rate ( more harsh ride i presume) and the ome coils are the same spring rate just taller. I don't care to have a stiffer spring but a higher ride height. Is it possible to just by the rear 2" lift springs from ac and just put spacers above my stock coils. What issues would this cause. Is it a good/bad idea. I have read some of the posts of you guys who have lifts. If anyone that has a Qx4 that they switched the coils for the ome or ac could give me some insight from experience I would appreciate it. It is also my understanding that the QX4 and pathfinder's OEM springs are designed at a different spring rate.
  3. I am trying to install manual hubs, and I can't even get one of the frickin dust caps off! I'm going to freak out! Any tricks? I had the same problem about a year ago when i installed my drilled and slotted and I found that a monkey wrench works best to free the dust cap from the hub housing and then it will come off easily without pinching the hell out of it with some vice grips.
