motorizedmoose
Everything posted by motorizedmoose
  1. Just a follow up if someone face the same problem : Despite all efforts, I was not able to stop the leak So, I finally decide to replace the steering fluid cooler. I didn't mount an OEM, I bought a Hayden kit from ebay and mount the cooler in front of the engine water cooler : I plug it directly to input / output of the steering system (it bypass the fluid cooler tube, the red part on the schema above) I mount it a week ago, and since, there is no more leak at all ! (and I did city driving plus 500kms of gravel and offroad, so, it has been tested seriously ) thanks again Rebelord for you advises =]
  2. Thanks for the advice, I will change that (the hose and keep only the screwable clamps). Thx
  3. Hi folks, since a while, I have a leak on my steering cooling system : I have to refill regularly. So first of all, I have replace the hose ( 49725MB on the next schema) two times. The first time was with a hose that the guy from the shop told me it should fit, but it has a bit bigger inside diameter so I replace it in a short time by an another I found, with an inside diameter a bit smaller that the original one. But the dman leak is still here So, I begin to consider replacing the aluminium pipe, the one in red : What do you think about this move guys ? I'm not completely sure if the problem is not related to the hose (maybe the one is actually mounted don't manage correctly the pressure), but I was not able to find a OEM hose. thanks for your advices / help
