Gingy
Everything posted by Gingy
  1. That was my thought. The military will pay to ship it for me. The only rust i've found have been on the exhaust and a little surface rust on the hitch (removed) and the push bar. The frame is actually pretty solid. I know it's hard for a great answer w/o y'all knowing the truck but thanks for the insight.
  2. What made you decide on that? a swap has been in the back of my mind.
  3. silverton, could you describe how you used the jumper to bypass the amps? Pics would be great!
  4. I bought my 92 SE a few months ago as an Alaska beater to get me by. Completely stock 202k miles, doesn't leak or smoke. Will need a clutch soon. But other than the air shocks and the rear wiper, everything works as advertised. even the A/C. Paid $900. What would one of these sell for down in the lower 48? (moving south this summer). I'm trying to decide if i should take it with me as my DD or just sell it here in Alaska. Thoughts?
  5. Thanks for all the replies. I guess i'll just run new wires. and yes i'm sure the fade is set to the middle and not just the front speakers. I even hooked up the power wire for the factory amp in the new harness. oh well. Thanks for the help y'all. Happy New Year
  6. recently replaced the factory head unity because all it's features quit working. ordered an install kit from crutchfield and wired my new unit all up but only the front speakers work. I believe my path has a factory amp. could this be the reason my rear speakers will not work? Whats the best fix?
  7. what about shocks? i have 0 desire to retain the stock electric adjustable ones. will i need to account for the 2-3"of lift?
  8. Second on the Isolator question. given the age and mileage i might as well buy new ones but i've seen a mention about cutting the springs. Sorry for all the noob questions. I just want to do this right the first time.
  9. Schweet. waiting on the slave to get here. Hopefully soon. I've had to bleed it once never touched the dampener. Sent from my SAMSUNG-SM-G850A using Tapatalk
  10. Bought my pathfinder knowing the clutch master cylinder leked down. I was told by the p/o it was the master cylinder but wasn't sure. It doesn't appear to be leaking under the hood. HOWEVER, I just started connecting the dots with the what looks like old water stained aged carpet under the clutch pedal. Is it possible or common for these guys to leak back through the firewall? Sent from my SAMSUNG-SM-G850A using Tapatalk
  11. Would you mind sharing the moog part number? I'm wanting to go your same route minus the body lift. Are the JGC v8 coils progressive rate springs? Thanks for the help.
  12. DMA251 if you run across those pics please post. i'd love to see it. i'm not familiar with those pathfinders. I'm just getting into these things.
  13. My noise is only when the truck is cold. It's a good maybe 10 minutes before it quiets up. i can drive it park it and crank it again and it's fine if it has warmed up. I dont know which would be worse to have. Broken exhaust stud or lifter problems lol. hell at 202,xxx miles it may be both.
  14. Ol I was thinking as back spacing increased the further the outside lip is from the hub.
  15. Hopefully not too bad. i've got factory flares. a little is fine. i'm more concerned with rubbing but it'll be getting a little altitude bump soon. Thanks. Y'all guys are great. thanks for helping with all my noob questions
  16. Looking at a 15x8 procomp alloy wheel. Problem is the 4.5" backspacing. I'll probably be sticking with the 31x10.50 tire. I was trying to stay close to the 3.75" backspacing but that wheel is a beast at 27.8 lbs vs the alloy at 16 lbs. Will that 4.5" backspacing be anything to worry about?
  17. Thanks! I guess I didn't dig around enough on their site to see one with an e brake opening. I like the idea of security in the tuffy. I loved the storage and such of my old one.
  18. Ok I'll do some more digging. Thanks
  19. Got a little top end rattle maybe valve clatter... anyway Is there a way to adjust the valve lash? Is this a pretty common thing? I've also read that if the exhaust manifold is cracked it'll sound about that way. The noise goes away once warm as well. Thanks for any help
  20. does anyone know of any Ebrake relocation threads? I know toyotas i've had were equiped with the ebrake in the dash in the right knee area. I see a cutout for something similar in our trucks but not sure what it's for. The Ebrake is the only thing i really see keeping me from a tuffy box
  21. could that be because he's canadian by chance?
  22. I'd like to talk to you about your setup.
  23. Those can get pricey fast! I have one for motorcycle and love it though. I saw the smittybuilt gear covers. They can be accessorized with pouches on the back. Tactical looking which is ok but they don't cover 100% of the seat like most do
