Hi to the board.
Our son turned 16, and he really wanted a 4x4 to drive back and forth to school. I live up in the Maryland / DC area, and and most of the older SUV's we found were rusted out hulks. So - after much searching, we recently picked up a 1995 Pathfinder. It only has 100,000 miles on it and hasn't been four wheeling. The truck was cheap at $1,200, and although the suspension was bad and it was leaking from the water pump, it drove very nicely.
The interior was perfect - it was a one owner vehicle and the guy literally put seat covers on it when he drove it off the lot. The guy we got it from literally drove 5 miles back and forth to work for years, and did some basic maintenance to keep it up. But - it does need some work.
The first thing we did was replace the ESS as the speedometer stopped working. That was a quick fix, and now all looks good there. We cleaned everything off, an are ready to go.
My wife is a gem and likes to help out - we will be working on it moving forwards in three different areas:
The water pump is shot and is leaking through the weep hole and the timing belt was never replaced - so will do a timing belt and water pump replacement. Although it doesn't look like it is leaking any oil, I also ordered camshaft and crankshaft seals and may do those while we are in there. We got all OEM parts for the engine. I found the write-up by Doctor Bill on the timing belt and seals - that is some great work.
The suspension is shot - all the rubber is perished, and there is some rust - ordered new parts from RockAuto and will be replacing everything and putting in new struts. The tensioner rod on the driver's side was actually broken. So - we got the higher end Mevotech parts, which should be fine, and ordered a set of OEM tensioner rods to replace both sides.
Finally - there was some frame rust, but there is only one bad spot - in the passenger rear section. We are going to treat it and re-paint the frame. We got some Eastwood Fast Etch Rust Dissolver, some Internal Frame Coating w/Spray Nozzle, and a bottle of AeroKroil to help with those rusted bolts.
If you haven't used it, that AeroKroil stuff rocks!
So - we are hoping to be up and rolling with a fully functional, low(ish) miles Pathfinder in the next few weeks.
If this had been a Toyota 4Runner, it would have cost 3 to 4 times as much - so we are really pleased!
