tbmiller87
Everything posted by tbmiller87
  1. You can turn the dial to select auto or lock. There is a lever to select High, N, or Low.
  2. A couple of months back, I installed Warn Manual Locking hubs on the 97 QX4. I noticed that if I drive over 50-60 mph for over 10-15 minutes then my 4wd light would start to flash. I then got my wife to back up the QX4 while I looked under it. The cv axels are spinning even though the hubs are unlocked and the QX4 is in 2wd. Does anyone know why this is happening?
  3. The Procomp wheels, BFG A/T 31x10.50s, and Warn Hubs are finally installed! All went on pretty easy. Only need a little trimming on the rear of the fender wells. The Warn Hubs are a must have!!! I should have listened to AKPrecision and put a strut spacer on while I was in there. That will be my next project.
  4. The above picture is the vehicle right after I bought it. I tinted the windows and Plasti-dipped the wheels. The next step was to cover up the bad clear coat. I justed used Plasti Dip rattle cans for a quick cover up. Finally this is the R50 after the ac 2" lift. These 245/70/r16 tires wont do it. I need some 31/10.50s
  5. Thank you everyone for all of your input. I really do appreciate all of your help so far. Today is the day that I'm going to try to put this little. We will see how it goes. If I can figure out how to put pictures on here I will put them up. Any last tips before I start this lift?
  6. Hey, everyone. I just decided to start build up my 97 QX4. I hope I can get it looking and functioning as well as of you have your R50s. Anyway, my AC 2" lift, kyb struts and bilstein shocks came in a couple of days agos and the new MM hubs are on the way. I also have the new rotors and brake pads on stand by because I am wanting to change everything out while I am in their for the lift. I had a couple of questions that I am sure you can help me with before I start all of the work. First, is the vehicle going to sit level after the lift or should I get a strut spacer? If so, what size is suggested? Second, my struts didnt come with the ruber covers(I dont know what they are called). should I get some of those or would it be fine without it? Third, I want to put some 31X10.5x15 all terrains on it. I will get 3.75" or 4" backspacing on the wheels. I just want some cheep, black steel wheels. Any advice on where to get the wheels and tire the cheapest? Also, any other advice is greatly appreciated!
