erichasbell
    1996 Nissan Pathfinder 4WD
    XE
erichasbell's Achievements
  1. I don't remember the other 2 codes. Sent from my C6740N using Tapatalk
  2. The actual code said ignition primary confirmed code 1320 and I talked to several mechanics locally who said its a distributor problem and my research on forums all pointed the same way. Sent from my C6740N using Tapatalk
  3. Okay that sounds right and I did check the plug wires against the block not sure how accurate that is but they all had spark. I am going to check the timing next. As soon as a qualified mechanic friend can come help me there's alot I can do by myself but I don't put that on my list. If I wasn't working with such a shirt time span I would give it a shot. Sent from my C6740N using Tapatalk
  4. The vehicle in question is my lovely and previously reliable 1996 Nissan pathfinder 5 speed 4wd. It was having a problem it would start and drive in the morning then needed to sit for a while before I drove it again and would run sluggish and jump rpms or bog down and not want to go or it would drop to a rough idle and not go anywere til it sat for a bit. Now it threw codes for a distributor and a knock sensor and saying it runs too lean. After speaking to a mechanic I was advised to replace the distributor and knock sensor. After replacing these things it will crank sometimes rough and sometimes smooth but will not start. I have checked for fuel it has fuel no problem I have checked the wiring its wired right. I check the spark plugs there good so are the spark plug wires. I've checked the anti theft its fine too.I don't know what else to do if there is even anything I can do. I don't want to throw in the towel on her she's such a good vehicle. Does anyone have any suggestions? I'm at a loss as to what else I can do.
  5. Hey there everyone i was wondering if anyone knew of the best way to put an effective 6-10" lift on a 1996 nissan pathfinder. i am already getting ready to completely rebuild the transmission and transfer case with upgraded gears and the like. but before i do that i would like to stick a lift kit on it ..anyone got any ideas?
