JimArm
    1992 4wd, 5sp
    Skilled/Experienced Mechanic
    Rarely Go Off-Road
    XE
    Potter Valley, CA
1,723 profile views
JimArm's Achievements
  1. My bought new '92 Pathfinder was 30 earlier this year and reached 100,000 miles last week. It has been very satisfactory. A check last weekend showed no measurable wear on either original front disc and about 3/8" remaining on all original four pads.
  2. I guess that I've done about 25 filter changes at 100K. I did make a long spike to poke a hole in the top of the filter and then turn it 180 to drain it before removal. It sort of worked, but now I just pack the gap between the filter and the starter with disposable rags. That catches 90%+, but a good wipe down after a short trip helps avoid dust catching oil build up. It is one of the mysteries of life that, when regular changes at reasonable intervals are good, most designs make it difficult.
  3. Aaron: Good! Aren't you glad you didn't tear your dashboard apart? If I liked to ski, maybe I would try your approach.
  4. Another question that may benefit from experiences here. My bought new '92 XE 4x (almost 100K) came with only one zirc fitting on the rear driveshaft, that on the slip joint. The U-joints did not have them and neither the manual or the big workbook mentions lubrication. They do, however, have plugs on the spiders (not the caps). I think I put fittings there years ago just to add grease, then replaced the screws. After the better part of a day replacing the joints on my son's Toyota pickup ( 400+K) last week, I figured I would like to avoid doing so on my Pathy. Any ideas pro or con or experiences to share?
  5. I am sure nobody will be shocked at the news the gauge worked just fine all day yesterday. I don't want to argue, but I do not consider pulling the instrument cluster are replacing the voltage regulator with one that needs soldering in an easy fix. I would undertake that only with a complete failure of the dash units.
  6. I may have asked this before. On my bought-new '92 XE coming up on 100k, the gas gauge can't seem to make up its mind, occasionally showing full when full, then empty a mile later, then up and down, It could, of course, be the gauge or the sender, but the low fuel light never comes on. It must use a different sender. This is not serious, but I would like an easy solve if someone has it. Thanks, Jim Armstrong Potter Valley, CA
  7. After some more looking, it seems that the felt pieces may filter the intake for the evaporative canister. The part of the box above the filter, including the circular screen, look brand new, not even slightly dusty!
  8. I checked my air filter on my bought new '92 V6 (nice low 95,000 miles) today. it doesn't need replacement, but for at least the third time I got to wondering what the other stuff In the box is for. There are soft felt "things" held in by metal clips and some other stuff. They all look in good shape and I know if it ain't broke, don't fix it, but I am darned curious what they do. Also I wonder if the part of the intake that is inside the fender needs inspection. Feeling stupid after 27 years, Jim in Potter Valley, CA
  9. Perhaps if I had used the term "catch" instead of "latch" it would have clearer that I was not talking about the hinges. I could not find any discussion of either in the link above.
  10. I am glad there are folks still enjoying their old Pathfinders. I did search for posts about the tire carrier latch, the subject of this post, not the hinges. I would like to read any previous discussion of the maintenence of the latch if someone would post a link.
  11. This may be a "well, duh" post but worthwhile if it applies to your rig. I bought my '92 XE new and have swung the spare tire and its carrier open and closed exactly 3,292 times. Each time it has opened and closed just a little tiny bit harder than the time before. I checked the places it might be adjusted probably 14 years ago. I think the weight is best shared between the hinges, the latch and the support in between. Today, rather than try to adjust away its increasing stiffness, I got down where I could get a good look inside the latch mechanism. I oiled the shaft ends, then greased (with a Q-tip and lithium chassis grease), every part I could reach, paying special attention to places that showed wear and/or were shiny, maybe ten surfaces. After a thin coating and some opening and closing, it works so easily, smoothly and quietly it's scary. Five or ten minutes to a like-new assembly. Post if it works for you, Jim Armstrong Potter Valley
  12. The starter relay is right next to the battery, between it and the fuse box. It can and does go bad, often with strange symptoms. It is easy and fairly cheap to replace.
  13. The power steering belt is the easiest to replace, being on the front pulley. It also has to come off to do the others. I wonder if the lack of the splash guard contributed to its failure. My original point remains important: today is a good time to take a close look at the condition and adjustment of all of them.
  14. I had to R&R my alt and ps pump belts today. They don't need replacing at this point, but it seems that it would be really smart to do it before one or both break. We did them over my pit with the skid pan off and they were still a big pain to get off and on and re-tensioned. I think it might nearly impossible to do the job on the side of the road in an emergency. So if you any doubt about whether you might need to replace your belts, do it soon. Potter Valley, CA
  15. Thanks, I tried that link many times before it opened today. Even though it doesn't mention trying get more oil in the tranny by any means short of a new case (!!!), it sort of seems implied. I still wonder why Nissan dealers ignore this TSB. I think I will drain and fill keeping close measurements and condsider adding some above the fill hole, keeping track of that as well. I should mention I have detected no worrisome noises.
