I have made progress, at least as to being able to drive the car. I determined that the fuel pump was OK. I read that the vehicle would run in failsafe mode, so I could at least could get to the parts store. I tried to put in into failsafe. I tested the connection to the distributor for the cam position sensor, then clipped the ground wire. It ran fine after that, in even very hot outside temps. I'm not sure if it is in failsafe mode, or just disabling the sensor has made the difference. It runs fine, is NOT limited in rpm's, the only thing that is different is shifting. It will occasionaly stay in 2nd gear way too long, but the trans. has been going bad for months. I understand from this forum that the entire dist. must be replaced in order to replace the sensor. It does have screws that can't be removed. I'll replace it when I can. Jnnydeppluver, it you want to try this (at your own risk), find the connector in the harness leading to the distributor. The connector is right on the front of the engine. Unplug it and clip the black wire on the LEFT (passenger) side of the connector. (you should probly check with your ohmmeter to make sure the black IS the ground wire. Check continuity between that black wire and the engine block) Cut so there enough wire to solder it back together. The wires change color (?) at the connector for some reason, just look at the feed side (left). Make sure the key is off. I can't guarantee anything, but it has temporarily worked for me. It should be fixed properly for emissions sake, I suppose. Good luck. Jim
