ONCEBITN
About ONCEBITN
  • Birthday 12/27/1984
    Infinity Qx4
    Hanford, CA
2,016 profile views
ONCEBITN's Achievements
NPORA Regular (2/5)
  1. can i pull the rear shaft and tie it up, i dont think i can afford the full trailer
  2. im moving back home now that im done with school and i have a 2100 mile journey, i was going to rent a tow dolly and tow the qx4 back, its a 97. and im wondering will i damage anything if i do this or do i need to pull the drive shaft or will it be fine, or should i rent a full trailer
  3. yup want the clean look, i like the stereo the way it is but want to be able to play my ipod
  4. come on does any one know how to solder in the 3.5mm into the cd changer setup
  5. yea but i had seen a write up where some one soldered in the jack on the board and plugged in the ipod and used cd changer button to change to the input
  6. i looked but cant find the thread, i saw it somewhere some one had used a 3.5mm to install it into the bose 6 disc, ive seen the write up for it to use the cd changer button for it
  7. well ive adjusted it again just like the video and im still getting the issue, but no lights in relation to it
  8. yes i dont feel it unless stopped or letting off the gas, it dosent happen when running
  9. yes i am, the only issue im running into is the with the trans, im trying to find out if i need a diff trans or if i can use the trans i have, reason being is my cluster for the diesel swap only goes to 3k so i am worried about shift points and bogging, but doing the measurements it looks like it will bolt up
  10. im getting the parts together myself, im gonna use a monsterdog adjustable fuel pump with a water seperator kit with the stock tank, as for the measurments the trans seems like it will bolt up to QD32ETi
  11. i did the tps adjustment at least i think i did it right, but ive been having this weird like fuel bump when stopped with the truck in gear it dosent do it all the time but its annoying, could this be plugs wires or cap and rotor
  12. these are the codes i pulled form the ecm, the light went off and hasnt come back on yet p0120 p0733 p0510
  13. ok so I searched but couldn't find what I needed, the 4wd light comes on and the wheel indicator light went off, I need the procedure to check the blinks to see what's wrong, and a list of what they mean, I'm ony phone so if some one could copy paste I would appreciate it
  14. im not familiar with the knock problem but here is a link to a relocation i guess to see if it fixes your problem http://www.nissanpathfinders.net/forum/topic/34574-knock-sensor-relocation/?hl=%2Bknock+%2Bsensor+%2Brelocation
