I have a 1994 pathfinder LE Automatic, I am in canada (think that makes minor differences with some relays) was hauling a trailer and parked to unload, went back in and pathfinder wouldnt start, to clicking, nothing, lights and stuff worked and a boost from a helpful individual would not start it.
so assuming it was the starter i began looking around, I tried bypassing the solenoid, which I know lttle about these sorts of electrical things. I unpluged the clip leading to the solenoid and attached an alligator clip to the male end leading to the solenoid then touched the other end of it to the battery pos terminal, with the key in the on position. It sounds like it is starting but will not, mind you it does the same thing without the key in the ignition. so a freind suggested a relay, i spend the other morning swapping out relays and no luck, but maybe i did the wrong ones.
I was attempting to dignose the connection by attaching a multimeter to various points on the solonoid, however being so confused of which was which i got frusterated and started taking it out. realizing once it was half out how hard it is going to be i decided to sit on it and see what this forum had to offer!
