1shotkllz
    1995 Nissan Pathfinder SE
    Rarely Go Off-Road
    North Carolina
1,704 profile views
1shotkllz's Achievements
  1. I've been looking for a place to mount my machine gun. Or while crossing a river I can just do some fishing
  2. Today while fiddling around with new seat covers, I look up and notice a push release button on the outside of my sunroof "opener". I figured it was just there for looks. But, after looking at it more and then I thought "what if the sunroof is removable?". Then I figured it out! Push in both, one release on both sides of the push handle, and push the handle out will release the sunroof from the handle. Push the sunroof up all the way so that it's perpendicular to the pathfinder and you can see slides on the hinges. Just move the sunroof to the left and pull up. Wahlah. Now let it rain in your pathfinder.
  3. I actually ended up going back and getting bigger conduit hangers. they automatically come with a nut and bolt to keep it in. The shovels on the other hand are light, I haven't had a chance to replace the liftgate shocks since they were already wore out when I bout the pathy, but they hold up good. 80 something cents for a hanger and some screws and thats it. Sent from my SM-G900R4 using Tapatalk
  4. Just put this together the other day. Never again will I get stuck with no shovel to dig with.
  5. Well, after the mud hole I had a brake caliper get stuck and eat my brake pad and a little bit of the rotor. After getting my rotors turned and getting a good functional caliper from a pick and pull, shes good now! Manage to also get a sunroof cover too! Sent from my SCH-R530U using Tapatalk
  6. I found some quick sand and bottomed out. Water was up to the spare tire on the tire carrier! I'll be getting tires soon. Sent from my SCH-R530U using Tapatalk
  7. Took off the fender flares and mud flaps. Can honestly say it gives it a more simpler and cleaner look. Big project replacing the timing belt, timing belt tensioner, water pump, thermostat, distributor cap and rotor, and ignition coil. Wish me luck haha Sent from my SCH-R530U using Tapatalk
