ranki1
Everything posted by ranki1
  1. I actually just did this on an 04 that I recently bought and had to do some front end work on. There are two adjustments on each headlight, and they look like "bottle caps" with a small bolt holding them in place. The outside ones are low down at the back of the lights, and are the up and down adjustments. You don't mess with the bolt, just insert a #2 Phillips screwdriver into the hole so it can turn the bottle cap. I think clockwise is "up". and counterclockwise for "down". The one more easily visible near the top on the inside back of the light is the left/right adjuster. Mine had a metal cover over these two that I used a small screwdriver to pry them off. It takes quite a few turns to see any movement of the beam up or down etc, so stick with it. I drove right up to a cement wall so I could see the beam easily, then lowered my problem light down to the same height as the other one, then moved it in towards the center of the road a bit. After a test drive I think they are a bit low, OK for now, but will probably raise them both up a bit in the future. The adjustments took only a few minutes, figuring out how to do it took way longer.
