richwill68
About richwill68
  • Birthday 02/11/1968
    Actually a Terrano R3M
    Terrano R3m
Contact Methods
  • MSN
    richwill68@hotmail.com
  • Skype
    brillo.williams
    Kinross, Perth
    Australia
  • Interests
    4x4, motorcycles, engineering, camping, family, friends, fun, sun and seaside! Not necessarily in that order :)
richwill68's Achievements
  1. Swapped it out today and works fine! Thanks
  2. Ah, sometimes I get a click, sometimes I don't! That's the cylindrical shaped thing, right? is this a relay?
  3. Hi V8path, thanks for the reply. Motor works fine. Don't have a wiring diagram for the door harness so unsure which wires should be live. Any ideas?
  4. Hi All, My 1993 2.7TD R3M has me stumped... Have a really annoying intermittent fault - my drivers door switch panel (so all four windows) sometimes works, sometimes doesn't? Door lock/unlock works all the time. All other window switches operate their respective windows regardless. Have changed the switch for proven ones and the fault remains. Can't seem to find a broken wire either. Getting to my wits end here! Any ideas good people? Regards Rich
  5. Thanks, I'll give 'em a call. Were they expensive?
  6. AAAArrggghhhhh!!! I have the bonnet from hell . Removed all old crud / paint with thinners. Flat back with P240, P600, P1000. Sealer / high build primer, 2 coats and flat back between. Top coat of matte black (Same manufacturer and matching acrylic paint for the primer). Looked great for about an hour... Now looks like its got a shrinking plastic sheet with cracks and bubbles. I am not a happy bunny. Right, that's it, back to bare metal for you my lad. Now where did I put that angle grinder and flap wheel? Any decent paint sprayers in Perth?
  7. Just replaced my top pin with a 16mm high tensile bolt, 50mm shoulder. Large plain washers top/bottom and a Nyloc nut. No more rattle...
  8. Today, I mostly did the worst ever paint job of my life on the bonnet of the Pathy... Sorry old girl. I did, however, successfully replace the worn top pin in my tyre carrier with a 16mm high tensile bolt. Play is gone, no more rattle!!!
  9. All the time - an analogue wristwatch and a pocket knife, cash and a mobile phone. For trips out, depending on destination/geography/distance - On me - Gerber multi-tool, Opinel folder, fixed blade full tang camp knife, flint striker, lighter. In truck - Spare fuel/oil/trans fluid and brake fluid, fork/spoon/plate/mug, 25L water, tools, rescue equipment (Tracks, snatch strap/bow shackles, airbag jack, compressor, long handled shovel, rope), repair stuff (Silicone self amalgamating tape, insulating tape, duct tape, spare belts/hoses, nuts/bolts/washers, headlight/brake/indicator bulbs, fuses, reel of 30 amp auto wire, crimp terminals). Self inflating camp mat, hammock, tarp, sleeping bag, blanket, headtorch, spare LED torches, gas hot plate with spare cylinders, cook set, 2 x fire extinguishers. Spare Shades/boots/socks and a wooly hat! Umm, sometimes more...
  10. Hi ebayfish, thanks for the reply. OK, now you have my attention... What might that look like, can it be tested or is it a case of junk and replace it as a case of trial by elimination? Rich
  11. Hi All, I'm having an intermittent problem with the power windows on my '93 R3M from the drivers door switch panel. Have checked wiring for breakages, switch is all good... All other windows will work fine from their individual and respective switches. Very confuddled and need some advice! Also, anyone got feedback/advice about Ironman 4x4 suspension? Price looks great compared to others but that makes me rather suspicious! Thanks in advance, Rich
