alburk
Everything posted by alburk
  1. Anybody? They re-pop the front end caps...they're on Ebay. What about the backs? There has to be demand? I'll buy 2...lol
  2. Any body know where to find rear bumper chrome end caps?
  3. Thanks. Looking for a recommendation for a good one...good design, durable, etc. Andy
  4. Source for 95 Pathfinder spare tire cover exterior rack. Looking for a source for an OEM style spare tire cover for exterior rack. Thanks, Andy
  5. Looking for recommendations for a good bug stone deflector shield for a 95 Pathfinder. Thanks
  6. Energy suspension 7.3120 says its for rear control arms '95 Pathfinder. Anybody use these for the rear trailing arms/control arms on a '95
  7. I need to do some work on my suspension...95 SE 4wd My vehicle is in a remote place so I was going to just take a stab at what parts I might need... It has 90K miles and is stock/original. Any input would be appreciated... I'm thinking of tackling these parts first... Front: Front lower control arm bushings (is alignment required if I do these and tie rods are okay?) Inner and outer tie rods (if needed but will buy to have handy-alignment required I know) Strut rod bushings Sway bar bushings and end links Steering damper bushings Shocks Rear: Trailing arm bushings Sway bar bushings and end links Panhard bushings Shocks Zerks and lube anything that takes zerks (factory) I was going to wait and check the ball joints and upper control arm bushings as I think they are more involved and they may be alright. Also waiting on springs and shackle bushings...to see what the impact the above has first. Does it make sense to do it in steps like this? Any suggestions? Thanks, Andy
  8. 95 pathfinder 4wd SE Who makes trailing arm bushings... So far found Whiteline for $70 per side is that the best option? Can they be pressed in with a vice or do I need a shop press?
  9. I am looking to replace my muffler with this Walker 18321. My Pathfinder is in another location so I cannot examine it. It looks like the front bolts on to the catalytic converter (flange below). Does the back bolt up or is it welded to the remaining tailpipe? Thanks for help. Andy
