Superkirby
    1995 Pathfinder SE V6
    MN
Superkirby's Achievements
  1. Got everything ordered tonight. I ordered Gates everything. Hopefully it will be here Thursday and I can start working Friday morning before work. I figure it will probably take me 2 or 3 mornings of work since I only have 2-3 hours at a time. But I'll get it done. Thanks for the help. Vince
  2. One other question, sorry. Do I want the idler pulley or the tensioner pulley? What I thought you were talking abut was the tensioner pulley that tightens the belt going to the AC.
  3. Thank you very much for all you help. I will get everything ordered this morning and so hopefully it ships tomorrow and then I should have it Thursday. Precise1, based off your description I'd bet it's the idler. I was talking to a buddy and he asked me to describe the noise. Best I could come up with was trying to rip a cat in half. All that said, I'm still going to order the whole shootin' match. I planned on changing the timing belt and water pump in the spring anyway. I have to change my thermostat before it gets any colder, if that's even possible. I don't know when the belt was changed last, so might as well get it done instead of draining the radiator twice. I changed a timing chain on my 72 mustang back when I was 15 trying to get the thing running. That was almost 15 years ago. I seem to remember it being pretty straight forward, just tedious. I realize there's more to this, but it seems to still be fairly simple, just a lot of time. Is that correct? Anything special I should know? I know I'm supposed to mark the timing gears before pulling them off to get everything lined up right when I put it back on. Anything else I need to know? Any special tools? Thanks in advance. I appreciate the help.
  4. Looked around on Rockauto. I can get the gates water pump and a different brand belt that comes with the seals and has a better warranty, plus the bypass hose for $65 and change before shipping. I don't know about a 5% discount code, but I'd be ok with using it if someone wants to share with me. I'm going to order the parts probably tomorrow. I actually just got the thermostat a couple days ago and haven't had a chance to change it yet (I have almost no heat). I was wondering about idler pulley but it's seems awfully loud for something like that. I guess I should check that out. Or... I just looked and I can get one from Rockauto for 13. Maybe just tack that on as well.
  5. I think its my water pump that has started making a lot of noise. It doesn't sound good. I thought it was my power steering pump at first, but closer inspection and it appears to be coming the water pump. As I understand it, if I have to change the water pump I might as well change the timing belt. I was going to get this kit. Is it my best bet or can I get better/cheaper parts elsewhere? http://www.ebay.com/itm/94-95-Nissan-Pathfinder-3-0L-V6-SOHC-VG30E-Timing-Belt-Water-Pump-Kit-/400441521876?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1995|Make%3ANissan|Model%3APathfinder&hash=item5d3c2cb6d4&vxp=mtr Thanks.
  6. I don't think I can access the terminal to tighten it. The wire is corroded about a quarter inch, if that, from the connector. I'm thinking cutting a terminal from one at the scrap yard with several inches left and splicing together will be my best bet. I'll take pictures tomorrow to better demonstrate what I'm talking about.
  7. Is there a place to get the terminals? Would it be better to find a connector from another vehicle and splice it together? There's several wires that are pierced, just one so far that's causing problems.
  8. I think I finally figured out where my problem is coming from causing my rough running. There's a couple wires that have been probed at some point with a multi meter. Problem is they went through the jacket and tore it up pretty bad, so I'm assuming it's corroded. I can move the wire around and here the engine change when it's running. So what I need to know is, how do I get the wire out of the connector? It's the yellow wire running from inector #2, at the plastic connectors above the passenger valve cover. It's the left side connector, where the wires eventually run back to the ECM. There's 8 wires in the connector, and the middle of the connector is a different color plastic (yellow I think?). I need to take an inch or so off this wire and I suspect all my problems will go away. Is there a way to get it out of the connector? It looks like the middle should pop out, but without a lot of prying and risk of breaking something I so far haven't gotten it out. Can anyone help? I can try to get a picture if needed. Thank you for your help. I feel like I'm finally about done with this problem.
  9. That's what I was thinking so changed the connector. Still nothing. After playing with wires - literally, I was trying to trace the yellow wire off the inector back to the plug and essentially ended up moving them around a little - it worked great for the last few days. Finally last night I noticed driving home from work there was a hint of a stumble creeping back in on occasion. If it follows suit like it has in the past, it should be an on and off problem today and pretty much a constant issue after that. The new harness should be here tomorrow or Tuesday and then will get it changed out and see if that helps.
  10. I read somewhere that the only difference between injector colors is the spray pattern. What I read said Nissan spent a lot of time playing around with different spray patterns to see if they could improve power or gas mileage with something simple like injector nozzles. The different color dots differentiate the nozzles, and as long as you have all the same color it won't matter. Anyone know if this is true?
  11. Didn't hear it run. It's already pulled out and sitting on a pallet. I haven't got it yet. I'm still trying to line up someone to give me a ride in their truck to get it But I'm trying. I wanna get it though.
  12. First off, Vividkid - your Pathy in your picture is awesome. I want that one. But anyway, I found a wiring harness at a junkyard. Well, specifically, my dad found it out in WY at a junk yard. But for $40 plus shipping it should hopefully take care of my problem. I hope. I plan to swap the harnesses and then I'll try to pinpoint the problem and replace the wire so I have a spare. Just in case. So that's where it's at. I'll hopefully have it and get it swapped out in about a week. Thanks for the help I just might win.
  13. Thanks guys. I found a used harness for $40+shipping. I'm going to pick that up and change it first and if all works well I'll pick up the engine if it's still available. But I don't want to spend all my money on the engine and then still have to spend money on something else to get it fixed.
  14. I've been looking for some used engine parts for my 1995. I found a good running engine from a 1994 for $220. It seems like it would be worth it for the parts but before I pick it up I want to make sure that parts from a 94 will work on my 95. Can someone please confirm this? Thanks.
  15. I removed the MAF and cleaned it and it didn't seem to make a difference in anything. It looks to be in acceptable condition as does the wiring to it. When I first narrowed it down to the #2 cylinder, I found I could disconnect all the injector connectors one at a time and #2 was the only one that didn't change how it ran. Changed the injector first. Still the exact same. Changed the connector and again, still the same. This injector has a white/red wire running to it and a yellow wire. I believe the W/R wire is common to all injectors and the yellow is #2 specific. After I was done changing the connector and nothing improved, I was trying to remember what briefly made it better in the past, which was taking apart and cleaning the plugs up above the passenger valve cover. So I moved to those. The yellow wire runs into the lower connector. Pulled them both apart to inspect for dirt and damage. Didn't see anything. Looked at the back of the connector to check for wire damage to the yellow wire. None that I could see. Put them back together. Decided just for kicks to start it up. Sure enough it started up, the CEL went off right away and all was better. Idle is smooth and consistet, blip the gas and it quickly responded, etc. Basically it ran like a v6 should when running on all 6 cylinders instead of 5. Through all this I've concluded my issue about has to be either the connector or the yellow wire. But which one and how do you tell? Better yet, how do you fix it?
