rbaum94
    1994 XE-V6
    Do Not Go Off-Road
    XE
    tampa
rbaum94's Achievements
NPORA Regular (2/5)
  1. I noticed gas smell while driving down the road and pulled over, right underneath the plenum where the 3 injectors are in the middle I noticed satuaration on the 2 in. gas hose, but the hose itself wasn't leaking. I followed it to the first (closest) fuel injector under the plenum and discovered it was leaking at the rain and I think it looked like the rail itself was getting burned and I could see very faint smoke coming out. I turned the car off and let it cool down and some sort of crust developed right in the small centimeter crevice between the fuel rail and the plenum at the first fuel injector and the smoke stopped. Turned car back on and the leak stopped and the saturation is gone. Anyone else have this happen?
  2. I guess I could cut the shroud out. If i drove without it on it wouldn't cause too much trouble would it? I recently had some damage done to my front end and now the fan scrapes the bottom of the shroud pretty bad so I'd just rather do without it right now.
  3. without removing the fan or the radiator/hoses? I guess i can't get away with not removing the radiator hose at the top, but after that can it just be pulled right out from between the fan and the radiator?
  4. this would be awesome! Do the bench seats in a hardbody have the same brackets as the pathfinder? 8 bolt setup? if so what year hardbody should I be looking for at the junkyard?
  5. Thanks for the info guys, I'm gonna check the connections to the batt and the coolant temp sensor, but I seem to have fixed my problem. I asked for advice from the previous owner (my dad) and he said it could be that the maf sensor was dirty, I pulled it out and cleaned it off and seem to have fixed my loss of power and surging issues, but I still have a really low idle, about 400 rpms (just bareeely above that first tic mark from the 0 tick mark) so I'll check those things you guys suggested and see if I that fixes anything
  6. Just started my day like normal, drove it for a couple hours in traffic, ran some errends, no overheating or anything like that, and then on my way home out of nowhere I come to a stop sign and the engine startes surging from the 1rpm tick mark to about dead (0) and then back up until it eventually just died. I pulled over and parked it waited a good 10 minutes for it to cool and checked the oil, it was about halfway from the full reading so I poured in the rest of my quart that I had left and started it. Still surged but I was in the middle of freaking no where and am currently unemployed right now so theres no way I could have it towed so I started her up in neutral and easily gave it some gas and drove the rest of the way home Eventually it stopped surging but it is very hard to get up and go like it lost power or something somewhere but once it gets up to 2-3rd gear it drives fine. 220k miles Any help guys? Would really suck if my pathy is dying now... Got a job interview tomorrow morning..
  7. where does the cable start and where does it end? I have the same engine 1994 pathy and my trip and odometer stopped working months ago, assuming its the sensor/cable. lol
  8. I just thought that if there was no oil on the dip stick at all, that would mean that it would be a couple quarts of oil gone, not about only 3'4ths a quart..
  9. I went and checked my oil today and there was no oil on the stick at all, triple checked.. Poured in about half to 3/4th a quart of oil and it was back to the full reading, also triple checked. Is this normal?
  10. nah, I only siliconed the part that the rubber insert goes into and only on the outside haha..
  11. Probably a good bet.. damn.. just siliconed the thing on there! lol
  12. I just got a new wiper fluid reservoir tank, replaced all of the hoses to the fluid shooters and to the tank itself, pulled out the 3-way and made sure it wasn't clogged, and I'm getting low pressure, it barely hits the bottom of the windshield. Every once in a while it will shoot out correctly but only during that one time that I pushed it and it worked.. Could this be an electrical problem?
  13. Yeah, i'm ordering a dayco timing belt + tensioner pulley, driveworks waterpump w/gasket and an oem thermostat. Anything else?
  14. Is there anything necessary to also change out while I'm doing this? Besides those 3 items, will I need anything else?
