red95xe
Everything posted by red95xe
Custom Tuning a Pathfinder ECU, the Project begins.
red95xe replied to Nefarious's topic in 90-95 WD21 Pathfinders
Props to you sir. Keep up the good work. -
Honestly, I think the stock Y-Pipe would choke off any gains to be had with the headers. If you do headers then you'd benefit from an appropriately sized Y-Pipe. I'm also interested in fitting the Z32 headers (with the D21 exhaust flange welded in). What I like about these headers is that they are about one half the cost of other WD21/D21 header options. And if you have a 2WD V6 Hardbody like I do, then you've got to get creative.
Pretty cool. Is there any performance benefit above and beyond a perfectly good working OEM distributor? Aside from timing the ignition further. I ask this because I have the MPFI with ECCS. It pulls the timing back if you try to advance it manually. At least that's been my experience.
The quickest/easiest way to go VG34, in my opinion is custom pistons from EP Racing. Any bore size along with 9.5:1 compression ratio you like using stock sized pin bores. For $885.00. With these pistons you can use the stock rods and save some money. For me, it's way over my budget. Plus, the shortblock I'm looking at is already assembled with OEM pistons (8.9:1 C/R - Close enough) This is the newest forged piston out on the market that EP Racing has designed in conjunction with CP Pistons. This is a true 9.5:1 piston. Once compression is calculated this piston puts the engine at 9.2:1 compression PERFECT for boosted applications. Available in any bore size needed. PRICE – $885+SHIPPING Specs: Full Forged 2618 Aluminum Twin oil feed with radial groove for pin bore HD wrist pins Full floating pin bore design Lateral gas ports Steel Nitride top ring Napier Second Oil ring standard tension Flat top design Valve reliefs are spec’d off at 1mm oversized EPR logo for quality assurance Light weight Radial side wall for added strength
I've read up on the VG34 quite a bit. Cool motor. I'd love to do it, but I've got a budget to stick to. As far as the OEM computer, there's a guy over @ Z31P with a Hardbody Truck making 216HP with a VG33E - 11:5 compression, 270/.465 cam, and a pair of killer ported heads. Other than that, I'm aware of two S12 guys making 171HP - 172HP with VG30's. Track only cars.
OK, I remember reading something about that build over @ Z31P. It started from a intake spacer review (which I plan on doing).
10:1? Is that the VG34 setup? Or was that custom pistons. I know the 3.0 has flat tops, I don't know of any 3.3 flat tops other than custom ordered.
Cool, I'll PM him some questions about that.
As of yet, no. I've emailed Mr. 510 about this, haven't gotten a reply back. It looks like the Thorley solution has the most potential. It looks like the headers themselves will fit, It's just a matter of modifying the Y-Pipe or building a new one all together. BTW, I've seen all your vids. on Youtube. Pretty cool. I'll check them out again. Thanks.
I've got another lead on a brand new VG33E short block assembly with oil pump for about $700.00. Unfortunately, it has the larger crank snout. My question here is: Has any one used Mr. 510's crank snout adapter with success? Thus being able to re-install the alternator, power steering pump, and A/C compressor with out any modifications.
For the most part, there are 3 ways to make power in the VG series motor: More displacement, Cams, Exhaust (headers). Of course there is more, but those are the most effective. Thanks for taking interest in this build. An extra set of eyes always helps.
Sent PM sir.
Just found a VG33E block for $200.00, 17 miles away. Does $200.00 sound about right?
Good deal about the LSD. I'll give Mr. Alkorahil a shout and see what he thinks. Back to the motor deal. Some thing that I recently remembered was how the Frontier/Exterra guys were complaining about was how down on power their motors were. A couple even took theirs to the dyno and came up with 128HP and another came up with 132HP to the rear wheels (stock everything). That's what a VG30E puts out on average. So that got me thinking about how the extra 10% displacement is offset with a slight loss in compression ratio. It's still a tough call, I was hoping to get through this build at about $1,500.00+. I'll check the Pick-N-Pulls again to see if anyone has a VG33E block cheap.
Mine spins the opposite yet all my vehicle records say that I have an LSD. Well, I guess they lied.
I haven't had any luck. I may have to try outside of the Atl. metro area.
As far as a LSD goes, all of my records say that I do. However, all I've ever experienced is one-tire-fire when I jumped on it.
Actually, it's not too late to go VG33E. I haven't bought the pistons yet. If I go VG33, the cost of the build increases $450.00 for a JY block and Sealed Power pistons. I haven't ruled it out yet. Here in the south, the JY's want $800.00 for a decent motor. The block on the engine stand is a JY block that has blocked coolant passages and a bad crank. This time, I want to be sure everything works.
It does have Pathfinder rims on it. So we got something in common. One of the reasons that I post here is that I find the Nissan Hardbody sites really lacking in technical - Know How.
Here'w where we're at. The original motor has a spun rod bearing. The replacement motor has a bad crank ( broken snout and bent ). This motor will under go a full rebuild with original crank turned down and new, upgraded internals will be installed with the reground cams that I just got in today. The specs. on the cams are 264 dur. - .450" lift - 114* LSA. This explains why the header choice is so important. I'm hoping for a pretty quick street truck. However, even with cams, intake, and exhaust, these motors still struggle to make over 175 HP to the rear wheels. Bummer.
Actually, It's a rather ordinary looking red D21 with the XE-V6 decal on the side. I'll wash it and post some pics for everyone. It still looks pretty nice and it ran flawlessly. Until I redlined it doing donuts about 5 years ago. Since then, It sits in the driveway. Get's started about every 2 months to keep stuff from freezing up. I have a replacement motor that's torn apart ready for the machine shop ( complete rebuild ) w/ soon to be Ported and Polished heads, new valves, valve springs,...the whole nine yards. Pistons, crank, etc. ( I'll take pics of my work area ). Back to the headers, I should have mentioned earlier that the Pathfinder's Long-Tube Pacesetter's and OBX's look as if they are going to run into the torsion bars. I can see where there is more space for the header collectors and Y-Pipe. So I counted them out from the get go. Otherwise, I had planned to the OBX route and have them Thermal Coated.
Good pictures as well sir. From what I see here, it looks as if both the EE and DT headers will fit to the block & chassis without too much drama. The hard part is where the Y-Pipe comes into play, if at all. I would think a high end exhaust/muffler shop should be able to handle the job well enough. Yesterday, I sent an email to EE to see what they know about the situation. I might just direct them to this post as well. Now I have to ask myself if i want to take a chance on a few hundred dollars purchase just to find out. If all else fails, then I have a final option. It would be enlarging the opening of the exhaust manifold by about an 1/8 of an inch. And then port/polish the insides the best I can. After that send the exhaust manifolds out to have them Thermal Coated. Finally, rebuild the exhaust system from the manifolds to the catalytic converter. I'm currently running a custom 2 1/8" cat back system. First, I have to get this motor rebuilt, I'll be running ISKY regrinds ( 264H - .450" lift). Now you can see why it's important to get the exhaust system sorted out.
Well, here we go. I hope these pics. give enough info. on the 2WD/5-Speed header options. My measurements on the TB's are 40+ inches long and they are equally spaced 20 inches both front and back. Here are my thoughts. It looks as if either EE and DT Headers should work because of the location of the collector. However, they are pretty pricey for the amount of power you get back from them. In reality, I was hoping that the OBX Headers would fit with no problems because of the price ($185.00).
Good Deal. At best, I'll be able to post pics with measurements tomorrow. No time for it today. As far as the body lift goes, this truck is not lifted. It's more of a street truck. You'll see tomorrow.
