pathy97
pathy97 last won the day on December 30 2012
pathy97 had the most liked content!
About pathy97
  • Birthday 12/31/1965
    1997 pathfinder,lifted 3inches in front 4 inches in back.2 inch wheel spacers,31/10.5R15 Treadwright Guard Dog tires.Cold air intake. Adjustable camber bolts.Push bar/brush guard w/lights.Light bar.
    XE
    Argyle N.Y.
2,228 profile views
pathy97's Achievements
  1. Looks great! A few questions. 1. What inch lift are the front coils? 2. Link to site you bought them from 3. Where did you take that 35.7 inches measurement from? Thanks
  2. Cant locate it but thanks. Im confusing some parts. What does the purge control solenoid valve look like? Im getting conflicting info.Thanks
  3. Where is the Evaporation Purge Valve located? I thought on the canister but someone on Nissan help.com said its in the engine compartment. Im confused.
  4. I fixed the P0130 and P1447 codes and now P0443 is showing up. WTF!!! Is this the purge volume control solenoid valve?
  5. When you said Decelerate with using the brake [or the clutch!] by coasting down to 20 MPH or less, then stop the vehicle. Did you mean without using the brake?
  6. Hey Towncivilian can you PLEASE tell me exactly where in the ec-40 that is. I cant find it,thanks
  7. Hey Towncivilian can you PLEASE tell me exactly where in the ec-40 that is. I cant find it,thanks
  8. I replaced the right side upstream o2 sensor and it was black/foulded what could cause this? A vacuum leak? It doesnt burn oil.
  9. I replaced the right side upstream o2 sensor and it was fouled/black. Could a vacuum leak cause that?
  10. Thanks. Thats how much I had to drive last time I wanted to go through the drive cycle
  11. Thanks I will try that as driving 176 miles costs $ as far as gas goes. Do i need to clear out the codes first( I own a scanner) then do the Generic OBD II "Drive Cycle"
  12. Thanks for your help. My truck runs very good,thats not the problem. Question is there anyway besides driving 176 miles to get the ecu to run a circut and clear the codes. I know i can clear them with a code scanner but then i cant get it inspected because the monitors wont be ready,Thanks
