Griffy74
Everything posted by Griffy74
  1. Tool box and somebody to push IF I get stuck
  2. What could be causing the miss fire then? The compression is good, I replaced the plug, wire, distributed cap and rotor.
  3. It is a V6, something I probably should have remembered to say.... Thanks, I'll check to see if I can find the washers and treys
  4. Hey guys! So I have a missfire in my number 2 cylinder and found out that it is the valve cover gasket. When I pulled the spark plug for a compression test, the plug and wire were covered in oil. The compression is right were it should be. I'm about to get greasy and replace it but before I do I was wondering if anybody had tips, tricks, advice, or warnings that would be helpful. It's a 1988 2-door SE. Thanks Guys!!
