D3RTAL3RT
Everything posted by D3RTAL3RT
  1. good to know, The cam gears and the crank sprocket are interchangable though yes? I was going to use the 91 donor motor timing sprockets and my timing belt from the 95 motor cause i just did it and the water pump about a month ago. . Thanks again!!
  2. Alright thanks bud, i was just combing through the forums and found some cory guy talking about making custom headers and saw your posts. Was going to give you a thumbs up, what a 19 y/o hey. Fake MPGs off the top of his head. fake dyno slips lmao
  3. Im looking to replace both heads, i see 2 castings avail (L-85E and R-85E) I have a 1995 XE and my question is, I believe the L and R are just to determine which side they belong to ya? Or is there a driverside R85 and a Passenger R85 and vise versa with the L85 heads? I found a long block for sale but i passed on the sale untill im 100% sure that its going to work for my 95, its a VG30 out of a 91pathfinder so it should all be the same ya?
  4. So the springs i used were the blue ones and ended up with 2.75in of lift in the rear. Then cranked on the torsions .5in and that gave me 1.75 in the front. drove 40km home after doing the swap and it rides damn near the same. Feels like a proper truck and the camber doesnt look off to the eye but an alignment and shimming is next. I found this install to be easier that rotating the tires, less nuts to remove!
  5. The seller specified that those springs are from the I6 and not from the V8. In the first page of this thread there is a little chart that is posted that will help you ask him the right questions part num code dia tag color 52001117 FH - .500 (grey) 52088102 FJ - .520 (green) 52088103 FK - .530 (yellowish. old part number 52001119) 52088181 FL - .540 52088361 FM - .550 (blue) 52088362 FN - .560 (yellow) [definately yellow, just got a pair] 52088104 GK 52088105 GL 52088363 GN - .600 52089141 GP 52089171 DL Ask if he can measure the thickness of the coil. I just bought mine yesterday out of a 96' but it was the 5.2l and the springs have a small blue sticker on them. Or if he could identify the color of the sticker if there is one.
