Everything posted by dthemiley
I'm going to ask, so I can try understand what is going on. Do the break light turn on? I will start looking at the wiring diagram to get ideas. Yup thats about it
Get ready for my new endeavor - MRJIM II
dthemiley replied to MrJim's topic in 86.5-89 WD21 Pathfinders
Good to hear things are looking really far up for you! Don't get a crick in your neck lol I'm looking forward to seeing the progress, I would fix the mechanical issues then revamp the interior and make it look better than new. Yup thats about it -
Upper control arm thread repair failed...Now what?
dthemiley replied to dthemiley's topic in The Garage
The drill in the kit is 37/64 if that answers the question. As to the damage I'm not sure what is causing it, It has always had washers instead of shims. I'm wondering if bad compression rod bushings and a big rock could of caused it? -
After wheeling over the weekend I discovered that the upper control arm spindle was sitting on the frame funny. It turned out I had stripped out the Time-Sert inserts I had installed in the frame. I've looked online and the Big-Sert inserts are not offered in M14x1.5. Do you guys have any ideas to fix this?
You wouldn't happen to have a part number for that would you? Yup thats about it
Thanks for the info. I just put the same shocks on tonight. I will give your recommendation a try tomorrow. Yup thats about it
Just to give an update. My ES3000 in the rear have failed already. Im guessing the 31 BFG mk2 MTs and 3" AC coils were too much for them to control. Yup thats about it
Hand-me-down 93 XE 2wd - 4wd conversion
dthemiley replied to dinrough's topic in 90-95 WD21 Pathfinders
+1 Mr. Ebayfish says. If it were my rig I would look into a rear locker and leave it 2wd. Yup thats about it -
Try a vg33 it should bolt right in and you will get more HP. ...
My 93 is at 236k Ive put about 45k on it since I got it almost 2 years ago. ...
So you replaced the compression rod that connects the lower control arm to the frame? If so check your torsion bar. It sounds to me that it broke or slipped causing that side to fall ...
Procomp es3000 ...
Yeah I had mine strip out when I put the UCA on. I just put inserts in all four holes. I ended up going back to the store and a different guy just exchanged them for 3 inch longer ones. I guess the first guy who helped me just confused me. I really like my procomps. ...
I bought new ones on ebay. Might look there. ...
Sorry the picture messed up ...
I don't have much experience with suspensions and such so I need help. I'm running a 3 inch lift. Putting in that was a learning curve all on its own. I bought some pro comp es3000 from 4 wheel parts. The guy behind the counter ordered up the stuff and sent me on my way. I pulled out a rear shock to compare to the original one. They are the same length. Im going to try and take back the rear shocks but what length do I need? I read somewhere that a f250 shock is the right length but does anyone have a measurement? Or did the ac coils I put in lift way more than 3 inches? http://img.tapatalk.com/d/14/04/01/ upy6a2yz.jpg here is the truck. ...
Try stockinteriors.com I think they sell some for our trucks. I didn't buy them but the carpet fits good. ...
Good thats what I was hoping for. One last question and I should be good for the rest of the project. I have the crank sprocket off and all the keys pulled out, how do I get that last ring off the shaft? Is there a snap ring or a trick I dont know about? ...
Im in the middle of changing the timing belt on my 93 because my crank seal has leaked oil all over it. I keep reading that people recommend changing the cam and crank seals while down there. I looked in my chiltons book to see how to get to it. Its saying I have to drop the oil pan to do it. Is there an easier way to change the crank seal? ...
HEPL PLEASE I think my timing belt broke
dthemiley replied to tsailor21's topic in 90-95 WD21 Pathfinders
Sent from my iPhone using Tapatalk -
Blue 93 build thread from the beginning.
dthemiley replied to dthemiley's topic in 90-95 WD21 Pathfinders
No they are 235/75-15 so roughly a 29 x 9.5 15. I've been thinking about painting them just need the time to do a proper prep before I spray them though. -
Alright like I said in my earlier thread, I'm starting my build thread of my 93 pathy. I'm mostly doing this so I can keep track of what I've done to my rig as I go along. This is how the truck looked when I acquired it in December of 2012. Didn't do much to it till my wife bought me my basket for Valentines day.
yeah its too bad but the thief does wear sketchers. I have two muddy foot prints on my new carpet to prove it. I'll get a picture posted as soon as I get a new charger for our camera, it was stolen too...
Well got the pathy back this afternoon. The truck itself is in decent shape. Some how they bent one of my wheels. Few new dents on my hood, my cross bars, basket, bike rack and kc lights are gone. The radio is gone along with my Dumb and Dumber sound track CD. Those bastards even took my bottle jack! Going to start the rebuild/replacing process as soon as we move in a few weeks. Coming soon...DIY Fiberglass cutout fender flares, DIY Snorkel, 2.5" suspension lift, 2" body lift, 31" tires, and new wheels!
