I got all the bolts but did not remove the xmembers. I cannot seem to get the torsion bars out where the connect to the control arms I did get them out at the rear. I was hoping I could slide it back far enough to remove and install a new clutch.
Im in need of some help here I have been trying to replace my clutch for a few days now, I have removed all the bell housing bolts the few bolts comming from the engine into the bell housing, the drive shafts. I cannot get the transmission to seperate from the engine. Any tips or tricks would help.
When I replaced the seals I cleaned and "scuffed" the sealing surfaces. I have 4 years automotive experience none of which are with Nissan. Some new info it seems to only leak when I have been driving for an extended time. Prior to replacement of the seals I drove 1 and a half hours and oil was almost a steady stream comming from the front crank seal area. After replacement of the seals it doesnt seem as bad but still leaks slightly.
Hey guys I need some help with this. I have a 87 pathfinder v6 I had a massive leak comming from the front crank seal, so I replaced the front crank seal both cam seals and the timing belt with all Nissan factory parts. But I still have the same leak. Starting to drive me crazy. Somebody help.
