alex1230
`89 terrano,bodylift,trailmaster suspension,winch,32bfg`s,cb,daily driver... ´92 terrano,v6,rollcage,special suspension,rollcage,other goodies in there...former u.a.e-desert challenge car.
30-35
1989
Reisbach, Germany
alex1230's Achievements
hi! but pickup-trucks are hard to find over here...even if they are diesels! they can´t be old or bad enough to sell them to eastern europe for lots of money..... hmmmmmmmmmm................................................ don´t know what to do... alex
now i know it´s a 2wd......conversion possible? does a vg30 driveline fit that automatic-tranny?
hmmmm..................on "myEbay" it´s still available.... let´s try this link... http://cgi.ebay.de/ws/eBayISAPI.dll?ViewIt...A:IT&ih=001
hi! seen this on ebay: http://cgi.ebay.de/ws/eBayISAPI.dll?ViewIt...A:IT&ih=001 those things are quite rare over here.... does anyone know if that is a 4x4? there´s a sticker on it that says trans: RE4RQ (?) 1A axle:HG39 i´ve an old `89 terrano left-can i do a 4x4 conversion? driveline is left-all stuff in good condition thanks for your help! alex
hi! awesome stuff! howabout shipping to germany...?
hi! much better today-í´ve got some pills and injections from the doctor. at least i can sit and walk again...
hi,folks! just wanted to tell you...on tuesday i wanted to change the clutch on my ´89-v6 terrano. but i couldn´t finish the job now-some muscles in my back popped out and i couldn´t leave the garage floor anymore. my wife found me some hours later and phoned up the doctor... but i´m feeling better now and hope i can finish the clutch duting the weekend. ALWAYS REMEMBER:a second pair of hands is really helpfull...........................
hi! i have the same problem...now and then. headlights always work well,but if i use the dimmer for the instrument lights,they cut out and with them the taillights are lost...i couldn´t find a reason now...the fuse sometimes is blown,sometimes not................ alex
thank you! my printer worked all the evening! lots of stuff to get through during the weekend... i´m quite sure i´ll get this thing properly working... alex
hello! something like that could be...that would explain the fuel consumption too. today,i changed the coils-just plugged in the original v6 coil to see what happens. it got better,but on speeds above 3000 rpm it seems that thing won´t get enough fuel,air or even wrong timing. :confused: as soon as the tachometer reaches the 3000 mark,any torque and power is gone. hmmmm......difficult to explain that effect-i can push the pedal further,but nothing happens. even shifting in a lower gear has no effect-all ends at 3000-3500rpm...it still runs fine,no stalling or something like that. it just can´t move the rig faster than that by any reason... to have something compareable-if it would be a diesel engine,i´d say it reaches its top idle speed and the regulator switches the hole thing off-and on again,as soon as idle speed drops. btw. does anyone know,which wires which ecu pin connects?maybe there´s something wrong with that. thank you all! alex
hi! i pulled out codes yesterday again-the ecu tells me "55"...nothing wrong there. but-fuel consumption is really bad now (needed about 15 litres/50km yesterday) and the engine absolutely has no power. today,it started to idle up and down with reaching normal temperature. rpm rises to about 1500rpm and falls to 800...rises and falls.... :help: i plugged in the diagnosis computer we use at work,but even that one can´t find some error. everything seems to work fine,but driving really isn´t fun now...i use the 2.4 coil now because all the connectors were the same as the 3,0 coil-maybe that´s what´s wrong? i even checked all connectors,the cap,rotor,plugs and all that stuff,but i can´t find anything wrong. compared to the 2.4,it´s like riding an old horsecoach now...
hi! thank you all for your help-just found the gremlin:there was some bad connection within the wiring harness... it´s running now,but with no power.i´ve tried to check the ignition timing,but the marks on the crankshaft wheel don´t fit with upper death center... during driving,it feels like that thing can´t idle up as it wants. i adjusted the ignition timing by free hands and it got better,but still hasn´t the torgue it should have. for example-in 5th gear i can hardly reach 110km/hour... alex
forgot to say-i have a black,a black-white and two black-pink wires left from the engine bay. on the engine,there´s one black-pink wire cut off...
hi! today i pulled the ecu codes.it says 11-crank angle/camshaft pos. sensor... i almost had that thought. some wires had gone lose fromthe right side of the engine bay withdirection to the distributor. i´ve soldered them together in the way it had some logic to me. does anyone know about the wire colors and their connection? alex
hi! hmmmm.........that may be! i´ve bought an old rusty vg30i terrano (u.s.-spec-model) and took all the stuff i thought i´d need. right this monent,i remembered i didn´t chance the pedals. what are those 4 switches for?.....maybe i should go out and try... alex
