Diego
About Diego
  • Birthday 10/06/1978
    1997 Stock R50 SE
    Skilled/Experienced Mechanic
Contact Methods
  • Skype
    diegomayan
    Argentina
    Argentina
Diego's Achievements
  1. Did you chek your outer tie rods? My '97 did the same thing, and replacing the outer tie rods solved the problem. Greetings, Diego
  2. I recently replaced my timing belt and water pump and have the same noise as you, and no leaks. Do you say that is only break-in and air bubbles in the coolant? I also replaced all the drive belts tensioners bearings with new ones. Sorry for my poor english, Greetings, Diego
  3. Thanks to all for the info.. I have a 97 R50 and the manual says to change the belt every 100.000kms (60.000mi) I changed mine with 110.000kms and the old belt is perfect. I also changed the water pump (Its the original that came with the truck) that was in perfect shape too... But you never know until you take all apart. BTW I put a new Gates belt. I had only one problem. When I first started her, it began to leak coolant from below the lower timing cover. I let her warm, stopped and when I came today to take all apart again to correct the leak, I started her again and no leak ???? It's supposed to be normal or maybe the gasket needed to settle with some heat??? Sorry for my poor english!! Diego from Argentina
