Lukemann351
About Lukemann351
  • Birthday 08/18/1981
    She is Black Betty, 1988, 2 door, Z24 engine...
    Skilled/Experienced Mechanic
    E
    Gladstone, Queensland, Australia
    Australia
  • Interests
    hunting, fishing, camping, and taking the long hard road to get there
Lukemann351's Achievements
  1. Does anyone know how to tell what model a carby is if it doesn't have a number on it?
  2. not much till roadworthy... cant wait to have her on the road...
  3. nah lost those a while ago... they are now housed in a silk purse, in my other half's possession... don't think i will be seeing them again...
  4. nah mine is a pov-pack... no cruise here... getting a carby kit for it... see what happens... just hope i dont loose the little balls out of this one
  5. Been going through the vacum lines to find blockage's and leaks... Not a lot of difference... Dropped by 100 rpm
  6. Any advice on tuning the OEM carby on a Z24 motor... Runs fine but idles at 2000 rpm... Adjusting the idle screw back any further only causes the engine to die.... I have slackened the throttle cable back, so it is not interfering with it... The only thing I can think of is the choke isn't coming off... Any other advise would be awesome... It has been at least ten years since I have had to play with carbs...
  7. i am going to purchase them and see how it goes... will post the results...
  8. Extractors, headers, manifold... Same thing... Just want to know if they are different or not...
  9. Ok... I am going to go with 2" body and suspension lifts... Still going to put UCA's in for reliability and movement range... 32" tyres should still fit...
  10. Do you need adjustable trailing arms for the rear diff for 3" lift... You get UCA's but wouldn't you need trailing/control arms for the rear?
  11. Extractors are a high flow exhaust manifolds used to increase speed of exhaust gasses over a OEM manifold... Dunno what you guy's call them then... As my original question stated will the "extractors" from a Z24 with 4 spark plugs fit a Z24 with 8?
