john&michele
    1987 Nissan Pathfinder 4x4 vg30i manufacture date 5/87 with a whopping 265,000 miles on it and no wear on the cylinders!
    Skilled/Experienced Mechanic
    XE
    fresno, Ca.
john&michele's Achievements
  1. i did a compression its good . ive check it again and it still has a miss . could the exhaust cause it to run badly ? i no it makes noise but could it make it miss? also if the distributer is off by 1 tooth could that be it also ? cause when i time it it will miss at 2 or 3 degrees either way .
  2. the timing belt broke while driving and bent three exhaust valves on the left side . i had them replaced and had the head checked out , it was ok so i replaced it and the timing belt . when i started it ,it ran good for a few minutes and then it started to miss . i checked everything i could think of that i may or may not have done right . it still has a miss and runs like (excuse my language)@!*% .... can you help?
