94Grinder
Everything posted by 94Grinder
  1. Repainted my pathfinder desert tan and blacked out the factory wheels.
  2. Tapping into the compressor clutch will cause the fan to turn off when the compressor cycles off. I will post a picture of A/C relay with wire color code when I have a chance.
  3. I had the same problem with a clogged line. I removed the rear brake light and cleaned sediment out of the nozzle and ran the motor to clear the line. Make sure you get all the debris out of the line or it will clog the nozzle again.
  4. I just replaced my washer motor with one from a 97 frontier. Only cost $15 at the salvage yard and it uses the same harness so it is a direct fit. The pump is made completely of plastic so I dont have to worry about the pump corroding again.
