mknight318
Everything posted by mknight318
  1. Wow you guys are great! Those are really good ideas as well. I might acyually get this thing running today and have my first Pathy experience.
  2. That would be bad. I guess I need to pull a rocker cover and luckily the easiest one to do is the one with the No. 1. Might as well get it correct. Thanks a lot!
  3. I have a 1997 SE 4x4 3.3, I just swapped the engine from a 99 to it using most of the parts from the 97 attached to it. How do you find TDC if the distributor was never installed on it and do not want to pull the valve covers to look at the valves? I used the service manual to change the timing and everything seemed to work out as detailed but now I have had a thought about something. Would the mark on the crank pulley for TDC always indicate TDC or are there several revolutions of this mark to get to actual TDC?
