1991terrano
Everything posted by 1991terrano
  1. dam!! im pulling 2800-3000 rpm at 100kmh on 31s!! are yours all autos? i have the manual box
  2. sounds like you have a bad earth some where id take it to an auto electrician and have them look at it, i had a similar problem in an r31 skyline no brakelights clock or dash lights, the main earth from the back of an aftermarket cd player came out
  3. yeeah lol i messed it up was 2 busy with the differences between the 2
  4. woahhh is that the diameter? thats more then 100mm bigger then either of the 2 i pulled off
  5. the 91 is a 2.7 turbo diesel, could you put a link up for this site please
  6. do the 90-95 pathys have bigger front brake rotors then the 86-90, i bought a 87 pathy for parts for my 91 terrano went to change the rotors over and the terrano ones were 10mm bigger in diameter and also wider seems like the car is pretty much useless for parts!
  7. on a wet road the front will slide out and youll probably spend more time replacing axles and differential parts then driving
  8. so many possibilities, it could be anything from a restricted aircleaner if your breather is connected to the intake to the engine not being run in properly and glazed the bores so that the rings cant seal properly
  9. hey everybody does anyone know of a supplier in australia that has 2-3" suspension lift kits including upper A arms, all i can find is 1.5" kits, im building up a beast of a wheeler but dont want to have to spend all my cash on freight over from the u.s.a!
  10. MATE! i love your work there!!!! i have just bought a 1991 terrano as a project and youve done all the things i had in mind, my turbo is away getting reconditioned i cant wait for it to get back so i can get stuck into it, what intercooler are you using there and where abouts did you mount it? would you mind if i asked you for your help/opinion throughout my project? as you seem to have these engines sorted =)
