beenthere
Everything posted by beenthere
  1. Change out headlight switch on 95 pathfinder. Have headlights(HI AND LOW),emergency flasher work, all bulbs good, changed flasher unit. Now when go to use turn singal all I get is a buzz from the turn signal flasher pod. New light switch did same thing. Tried new flasher, same thing. Fuses good. Need help in this.
  2. Right on with the left hand drill bits. Everyone who needs to remove exhaust studs broken off need to go buy some. Yes they do exist and the counter rotation of bits with help remove the bolt or stud.
  3. I guess I did not make it clear. The light switch is good. New one did same thing and tested in another vehicle and it worked fine. All lights(dash,stop,tail, interior and flashers work fine), just no turn signal. The quest goes on.
  4. OK here is problem. Nissan headlight switch went bad(the old lose one low beam light). Change out switch and all goes to working. Then go to use turn signal and get just a buzz from the flash unit. Replace flasher. Still buzz and no turn signal. Try new signal unit and still same result. Now I have headlights(high and low), have emergency flasher(work fine) but no turn signal(just buzz when you try them). Have traced wires with factory schematic and can find no problem. Called Nissan dealers(Ha) we never heard of this one, but for $90.00 we will look it over and see if we can find problem. Call asian repair guy, he said I mess things up because I change switch without unhooking battery. Call me shade tree mechnic. Guess what, he wanted $90.00 to fix my problem. Told him thats ok, I will stich arm out window before he gets any money. The end is has anyone run into this problem and send help. Getting older everyday.
