Litey
Everything posted by Litey
Manual locking hubs with stock 03-04 wheels
Litey replied to seeraedave's topic in 96-2004 R50 Pathfinders
Yes and As I read it the OP seemed like he did the spacers so he could put back on the factory center caps . But seems if you want to get at them quick and don't mind them sticking through the wheel you wont need the spacers and lengthening bolts .. maybe I am not reading right .. And yes that is a mystery on why that light comes on for the Auto mode owners ... even when my drive shaft was out of my PFinder for 2 weeks ... it was on and off erratically . but with driveshaft back in (and no locking hubs yet) it has been off ... -
I am going to send and show them this thread ... just for giggles .. they should know it fits ... but like I said if it triggers the 4WD light the application may not be perfect enough ... and they don't want the phone calls and returns .. but if I were them .. I would just put an asterisk next to the years it fits and have it read ... " * may cause 4WD light to come on " -
Well Thanks for Proving that they fit in and through the wheel . Don't know why Rugged Ridge won't say that they work for 2004 ...unless they just don't want to hear about the 4WD warning light complaints ....that will go on and off .. I don't think that does any harm .. -
I think that should settle it ! Thanks -
Hawairish , Thanks for the Reply , but I was asking because the Rugged Ridge will not admit they fit the 04's they only say to 01 ... the Mile Markers do claim to fit the 04 .. in the application guides or on their sites and yes looking to reduce motion and drag .. -
Before I pull the trigger on The Rugged Ridge ... 15001.61 is this the best for 2004 ? Pros and others (Mile Markers) half the price ... and also Rugged Ridge not supporting the 2004 in its application guides .. Anyone give me an opinion please .. -
Infamous shake body vibration between 45-65mph
Litey replied to BuffaloR50's topic in 96-2004 R50 Pathfinders
Just to be clear . I have not yet installed manual hubs . I have pulled out the front driveshaft , and have had it balanced , but have not re installed it . The Truck has no vibration , at all without the front drive shaft ... I have been driving like that for two weeks .. I just hope there is no harm in it ... The only thing that happens is occasionally the ABS light comes on . and Today the 4WD light came on ... Any way , I do plan to put the re-balanced front DS back in this weekend .and next step is to install the Rugged Ridge Manual hubs ... especially sooner if I get any vibration back . -
Thanks Rebelord , but thinking if vibrations gone with front Driveshaft removed ... the whhel bearings must be good ... but I will stay aware of them if any more vibration pop up in the future ... -
Thanks Rebelord , but thinking if the vibration is gone with front driveshaft removed ... Wheel bearings must be ok ...but I will stay aware of that if any vibrations arise in the future -
You guys are Awesome ... thanks so much !!! Going to get some Rugged's and get going -
Please Tell me if either need extended .. ..I guess I was reading that the wheel studs needed or were preferred to be extended by some ...but if there is a preference or need for other studs please Inform me ... -
Thanks totriz , found the info and that the Rugged Ridge does fit without spacers , but just asked on that thread if you still need to use longer studs or do the stock one work ?... ...with those LE Plat wheels
I have those LE Wheels pictured above by Lerch641 ... so No spacers needed ... Great news ... but what about studs ... were stockers they long enough or did you need to use the longer and switch them out ? -
Ok I just changed out both rear u joints ... no good ... still vibrates .... but they were crunchy anyway ... Just pulled the front shaft and yup ...no vibes ... so off to get a used shaft at junkie ...or have mine balanced ....and maybe do the hubs too if they will fit my wheels ... -
couple questions for Buffalo 1. What Brand Hubs did you use and did they fit without modification with those 17 inch Platinum style wheels ? 2. Any further progress on the vibration .. mine is doing same ... I have 2004 with 63K ... -
Hey Guys , Really am interested in doing the Warn Hubs or Pros ...on my 2004 LE Platinum ,,,, but does anyone know if they will fit with the special edition Platinum Wheels , they are 17 inch 6 spoke Alloy ....I am concerned about the diameter of the Hub center ID and the OD of Warns ... anybody know ? Any experiences? Thanks !!!
Hey Tungsten Thanks , But since new to Patherfinder ownership , can you or anyone link me to the ignition system issues and fixes so I can have like you say , a long running engine .. Thanks and sorry to have to ask ... I am searching as well ...
O.k. just wanted to say that this past weekend my good bud and I dove in ... we removed only the upper plenum and found very tight screws on my 04 LE . But we did our own Loctite blue on each one and put them back . I respect Bow Tied for his painstaking detail , but feel there were many ways to go around things to get to the screws . First we did not remove the Throttle body from the upper plenum ....rather left it attached and the coolant lines attached to it and merely just tilted the whole unit resting on the Throttle Body( TB) up in the air on the opposite side of the TB. We did remove the entire airbox previous to this by just disconnecting everything except that lower box and just jimmied it out of the place being careful not to get hooked on any wires or hoses . This saved lots of time ... we were done in less than 2 hours and even took a break to talk to some relatives that visted . We did use the torque specs from the FSM ... and used there tightening sequence .... but didn't replace any of the 2 gaskets from the Plenum housing ... but did use spray tack ...aerosol gasket seal ... on the old used gaskets which were very metallic or metalwrapped and in pristine condition ... I was am not trying to be cheap , and had purchased them but did not remove them from the box after considering how god they were when they came off . Anyway take your time and realize their seems to be a lot to remove ...but it was not a hard job .
Hey all , New here , And just wondering is it necessary to also do the swirl valve screws or just the Power valves screws with loctite ... If I only do the power valve screws am I short changing myself ..??? Also does anyone know the torques specs for the Intake ...i would think that would be important ..
