MudSlug
    Just BFG T/A MTs so far.
    Texas
MudSlug's Achievements
  1. Thanks, guys! I will try the TCU first, and then the solenoids if that does not solve it. Also, based on what I read on other auto trans threads here I will be adding a plate-style trans cooler and magnetic filter. I just moved to Texas from the PNW so heat will be an issue when the weather warms up.
  2. I have a 1995 Pathfinder LE 4WD. When I start it up, the automatic transmission starts in second and will not shift automatically. If I manually shift it with the gear selector, first gear is unavailable. However, once I get it rolling I can put it in neutral, turn the ignition off and then back on and it starts shifting perfectly normally, including first gear. I have to do this now every time I drive it. Turning it on & off while it is not moving does not make it shift correctly. It has to be rolling for that trick to work. Also, it will sometimes shift correctly on startup if it is really cold outside, but never on a warm or hot day. I searched The Garage and found no thread describing this or similar transmission issues. Any idea what the heck is going on here? All help is appreciated.
  3. I have a '95 Pathfinder. I have been looking around at front bumper or brush guard options, and there is not much out there. I would like something that could mount a winch. The ARB bumpers are not available any more, and are hideously expensive anyways. So what do I do? Go custom fab? That would probably be just as expensive as an ARB. Any suggestions?
  4. P1: Must... resist... nasty... joke... about... Canadian... girlfriend... Backing... away... from...keyboard... =========================================================================================================== So what is a good off-the-shelf cat-back system for my '95 V6 4WD Pathfinder LE? The former owner crumpled the tailpipe on a rock, so he sawed about the last three feet off the exhaust system. It is not too loud, but I want to go to a freer-flowing system with larger diameter tubing. And I do not want to burn $700 on it. I was thinking of just going to a good exhaust shop and having them fab me up something, but first I wanted to check on aftermarket recommendations here.
  5. I searched and did not find this question, so here is goes.... I have had a '95 XE for a few years. The transmission just died, and I managed to find a really good deal on a very clean '95 LE to replace it. But although the two PFs are the same year, the turning radius is far, far larger on the LE than my old XE. Why is that? Is there some simple solution to this? One thing that raised my suspicion is that the LE has a selectable suspension feature, with a switch to select 'Comfort' and 'Sport' modes. The 'Sport' mode tightens up the handling and stiffens the suspension noticeably. Do PFs with this option have a much more limited max steering angle? Any insight on this would be appreciated, because this LE has the turning circle of a Winnebago.
