Jackson
Jackson last won the day on September 9 2010
Jackson had the most liked content!
    Sold
    Rarely Go Off-Road
    I Wish I had a Pathy!
    Winnipeg Canada
Jackson's Achievements
  1. You'll be hard pressed to make a bar that is functionally better. This thing is pretty simple and adding gussets and heavier tubing will be offset by drilling safety holes in it. As far as we can see the stresses are in tension and compression only, so further stiffening probably won't make much difference in performance. I should point out the original prototype my partner came up with (he owned a Pathfinder at the time) was made from thin wall round tube, squashed flat on the ends, with a couple of holes drilled in it. It worked almost as well as our finished product. I have a couple of Toyotas in the shop right now - a 89 Supra, it has a similar lower stress bar made from round tube, pressed flat on the ends with a couple of holes punched in the ends. An MR2 has a cross brace over the engine compartment- same round tube... Feel free to make your own version, it could be done any number of ways. I could even visualize an adjustable bar with a couple of rod end bearings at each end, but again would it work any better? There is also a price point to consider - we made ours so cheaply that most people would just buy it. Some exotic version for a couple of hundred bucks would sit on the shelf a long time. By the away, our bar is TIG welded, and I had the end tabs laser cut - which, you have to admit, sounds very aerospace! John
  2. Imitation is the sincerest form of flattery! We're pleased to see our missing link being copied - we knew it would be! The one pictured above is a design we tried and rejected. It'll work fine, we just wanted to weld the tube completely shut so that it wouldn't fill up with mud, wet snow and, in our location, road salt. The distance between the mounting holes varies, both from production tolerances and even the most minor collision will tweak the unibody, so we made our holes slotted to allow for this. We didn't want anyone calling back and saying the bar didn't fit. Our design also has the advantage that it can be installed with a thicker wall impact socket or even a crescent wrench (not recommended !) Whichever one you buy or build yourself, one thing is for sure - it will improve your truck. John Jackson Jackson AutoSport Winnipeg Canada
