gas92
Everything posted by gas92
ya, i guess if its a finicky pos, ill change it out, hope this fixes the problem. ill let you guys know.
i was thinking about that. theres no engine light on, I dont even know if theres a light in there,lol as it is right now, there is no interior or floors in it, so i cant nbring it to the shop tell i weld new floors back in.
ya, I changed the filter to. I started it and unpluged the temp sensor, and it stalled out, does this mean the sensor is fine??
thanks alot for the help, I went out and checked it, the wires seame to be fine, started it unpluged the sensor to see if there was any differance, but couldnt tell. what way could i check to see if it is the sensor?? or check tyhanks again
hello, please help!!! so I have a 92, auto,that seams to bogg when i start it up and drive away. step on the gas like normal, and it boggs, if i romp on it it bogs, but if I push on the peddle about half way,off, on, off, on, it starts to go, but will bogg after this to, just for mabe a minute. it seems to drive fine after. it is getting worse, kinda had some poping noise come from the front, i think through the intake,only sometimes, but always goes away after a minute. Ive changed and cleaned, plugs,wires,fuel filter,tb cleaner,egr valve,injector cleaner,idle air valve, just sprayed it out, with tb cleaned, coil, computer from junk yard, altanator, mass air flow, spraied with tb cleaned. and the tb control, i took off, but didnt know how to clean, so replaced it with a good running motor, no change, with any of these things. lots of air released when gas cap is opened. while driving there is a gas smell once in a while??? not sure what other easy things to check, im out of ideas!! the battery was dead a few times in a week, so i changed the alt. but same problem, could the battery be almost shot?? Not holding a good charge?? what is a easier way to chech the injectors. without pulling the plugs?? well thanks for any help, it been going on for so long
thanks, just wanted to make sure. and this doner pathy is mint, brand new tires, tranny cooler with temp gauge, new axles and hubs, and lots more, all for $400 Canadian!!!! well thanks again. will try to get pics of body lift and body swap.
hello, looking at buying a second 95 pathfinder for a body swap, its in mint shape.My 92 body is shot, but frame still has black paint. the doner frame is shot, but body is mint. Now this is my question, will a 95 body bolt right up to a 92 pathfinder frame. both are auto, 4x4. also will be putting a body lift on at the same time, will i have any problems with that to. thanks in advance
so, it was the alternater, that was causing the sputtering, and running rough, we replaced it yesterday, now it runs perfect. we found this out by me dunking the truck up past my pass side seat in water, fried the computer. trouble shooted for six hours, coils, relays, and other @!*%. replaced computer, then truck would keep charge, everything else followed. all good now.
this is kinda what i was thinking, when it sits there, the battery looses juice. Im not sure how old it is, but probley going to replace it soon. for it running rough, all the other things are done.i fired it up for the first time of the day, for 2 min ish,then cleaned the idle air valve. put back togeather, drove around the street, it seemed to be better, but had alittle lag, or sputter. for the three weeks i drove it, since bought, it did the sputter, bog thing, but never stall. but 2 days ago, started up and test out my hubs, and it was barley moving, sputtering,boging, real bad, the worst yet. no back fire from exhaust, but the intake had some cough sounds coming from it. but 3 or 4 min later completely fine. noi smoke from exhaust, just alittle moisture dripping from tailpipe. anyh ideas, thanks for your help also the excessive air leaving the tank when opining gas cap, what could this affect, besides the tank expanding. thanks again
so if we drain the fulid and refill, do you change the filter also, silly question, but ive never changed the tranny fluid in any of the 3 pathfinders ive owned.
hello, i was wondering if a bad alternator not charging the battery would cause my 92 to run rough when first started up, tell couple minutes past. didnt start truck for 2 days or so, and battery was dead, then next day was dead again. i let it run for 15min the day before. once i drive, it fine, but if not charging properly, would this affect the computer and injectors.i did a complete tune up, throttle body control, egr valve, mass air flow, were all cleaned, and a injector cleaner through the tank. also there is a blockage in the fuel tank somewere, lots of air when gas cap opened, would this cause it to run rough when first started up. just trying to work all the bugs out. any help would be great, thanks
the cause of the play in the outer shaft,would that be the bearings. and the clicking,from the frontt wheels,what would that be from. thanks for the help. manual hubs are in the future
Hello, new guy here, had 3 pathfinders so far, and this is the first of this problem. when in 4x4, on hard gravel, i was given er up a hill, and i heard this grinding sound coming from front of the truck. like a drill chuck set to low torque. things i have done, pulled axle out, boots are fine, no play, auto hubs seam to be fine, re greased and put back togeather. befor i pulled the axle out, i just had the hub off, grabed the end of the axle spline,gave it a wiggle, with snap ring still on, there was some play in all directions. mabe 1/8 all around. is that ok?? also do i always have to back up to disengage the 4x4, i do it sometimes. thanks for the help
