yak
Everything posted by yak
  1. Hiya I'm not sure what the advantage of one of these units would be, the way i'm seeing it is all that it does is recieve signals from satellites and using bluetooth to send it to either a laptop or pda screen, you will need to have a laptop or pda for it to work, I'm guessing you have to have the mapping software downloaded onto your pda or laptop then this units sends the satellite signal to the mapping software. I just bought a HP ipaq travel companion for like $570 (aust dollar) it's a pda with tomtom mapping software built into it, I can't complain, considering the tomtom brand nav units were selling for close to same price, so i got the pda option for only a few extra dollars. That gps reciever will be good if you already own a laptop or pda and can access mapping software at a reasonable price.
  2. hiya Need to fix some rust that has developed under front windscreen seal at the top, water is leaking into passenger side, anyone have an easy way to remove windscreen without (hopefully) breaking it...i want to repair rust myself and get the professionals to re-install windscreen when im finished. I would get the whole thing done by a panelbeater but i've recently had the same problem with my corolla and it was pretty bad and cost a bit to get done, so trying to be cheap...thanks
  3. yak
    engine power
    where and what are these vacuum hoses? oh and unccpathfinder...i went up from 225/70R15
  4. yak
    engine power
    thnx for replys... i guess acceleration off the mark has only dropped slightly, it's more in 4th, if i get to even a slight incline it will go sluggish...then if on the freeway and whack her in 5th and it the same thing, the slightest hill and i have to go back a gear and i'm a bit slow getting her from 5th to 4th and if a drop too many revs will have to put her in 3rd to get back to speed. yeh i did the bodylift myself...just went down to a place called specialised wholesale in my home town that deal in engineering plastics and they also have all the bolts and stuff i needed...
  5. yak
    engine power
    maybe i need to turbo it would a turbo kit fit ...or would it wreck it
  6. yak
    engine power
    hiya was hoping for some advice...have a 90 model pathy Z24 motor...just recently put a 40mm susp and a 25mm body lift and put a set of 31" tyres on her...and now she has lost all power...any suggestions for getting some of that power back without spending heaps...it has a set of genie extractors and nothing else. In the distant future...maybe in a year or 2 i might replace motor but at the moment just want a cheap method if there is one... thanks
  7. Quick question...on my windscreen wiper lever there is a dial of some sort that turns on the end of lever and there are arrows marked on lever with a clear window that has a blue indicator thing in it...when you turn dial on end the blue indicator moves up and down...it lines up with either 1 arrow or 2 arrows or 3 arrows...can somebody tell me what it does...i hope that made sense...thnx
  8. yak
    stock height
    awesome that diagram is in the haynes book but i can't see those measurement anywhere...it says 'see specifications' anyways awesome thnx
  9. yak
    stock height
    hi all just wanting to know what the stock height of a wd21 90 model pathy 2 door (what measurement front and read) and do you measure from centre of rim to the wheel arch, just wanting to know for when I do susp lift in the next few weeks I want to measure now just to make sure it hasn't been lifted before, especially the torsion bars, I bought this car just before xmas and it has after market shocks in back, but springs look stock, and how do you know if the front has been lifted with the torsion bars...any help would be awesome thnx
  10. haha yes... funny story...me and mate 4wd one night, it was getting late so we headed for home (the bush tracks were only like 100 mtrs up the road from home) anyway we get home and forgot the hubs (so they were still locked in) anyway next morning off down the bush again, get to this awesome mud pit so we get out and lock hubs in (oh and the hubs have been that scratched up you can't see the arrows which tell you which way is which) so we jump back in truck and head for the mud...well about half way in and we're not going anywhere...look out window and realise the front wheels aren't spinning then remember not unlocking hubs from previous night...so out the window and onto bonnet, then reach down into mud to lock the hubs in...very fun
  11. that's awesome...thnx
  12. Hi all Just wondering if anyone knows of a website or link that has a walk through step by step guide to installing body lift kit, i've read most of the posts on here and they are a bit all over the place, like 1 post will say 'don't forget to undo such and such' then the next post will mention something else...it's hard to follow...i'm mainly concerned with the bits that need adjusting once you have lifted it like radiator/hoses, brake lines, i think i read something about transmission box, i just don't want to start and miss something and brake it...but also i'm only thinking of doing 2" body lift and 2" susp lift and i have read 2"b/l you might get away with not adjusting much...
  13. awww...i want a new bullbar now! hey you got a red pinstripe down the side of your truck...and it appears they replaced it when they fixed it...cool
  14. yak
    Kill switch
    awesome...thanks heaps for that. I don't own an R50 but can't see it being too different...i'll just keep cutting wires until one of them doesn't start the car when I turn the key and use that wire...then wire the rest back together
  15. yak
    Kill switch
    what an awome thread, im not that great with electrics but the kill switch hooked up to ignition sounds pretty good, can anyone go into a bit more detail, the only ones i find googling is the fuel pump method, so basically when you turn the key it clicks over the starter motor, is it that wire that you put the switch in? I read earlier about a white cable?
  16. yak
    wheel stud diameter
    awesome...thanks for that.
  17. hi, just bought a 90 model pathfinder, the front brakes were stuffed so i'm in the middle of replacing discs and noticed some of the wheel studs are stuffed, anyone know the diameter of them....is every car the same?
