qx4paulo
Everything posted by qx4paulo
  1. damn... i cant fit 15's on my truck and its near impossible to find 16's with 3.75
  2. i need new wheels.. just bought a set of 285/75r16... i have the 4" sfd so whats the backspace i would need for a 16x8 wheel or a 16x10 wheel...4" or 3.75... cant seem to find 3.75bp
  3. hey rod... i would just bring the link to a shop.... stuff is really expensive here in ny to do and it cost me only 40buck to remove the old bushings on all 4 links.... so i really recommend it... but if u did want to do em urself u need to burn em out and drill out the rubber then air chisel the sleeve out.. helps if u sawzaw a cut on the sleeves to relieve the pressure
  4. i think there are little elf's break stuff on my truck at night...the more i fix the more odd noises i get ...wtf
  5. hey so after all this money i spent my truck rides like ASSSSSSSSSSSS!!!!! so newww tranny from the dealer.. new suspention and sfd new rear upper and lower bushings all new fluids...rear diff..transfer case..oil change and after i installed the bushings an entire new noise happened. my truck around 45mph and up makes some loud drone noises... especailly when i let of the gas.. at first i though it was from low fluid in the T case but i change it again with atf plus dectron 3 or how ever u spell it!... anybody have any idea,,, its driving me nuts.... Also when i did the rear bushing the rear axle moved back a bit and the drive shaft fell out... i lined it up again and slipped it in and then changed the fliud... Help...last resort before the stealership trip
  6. were can i get a set of cragar d window rims...16x8 or x10 with the correct 3.75bp... cant find them on summit 's website or on ebay... anyone?
  7. there not really low pros... there 65 sidewall low pros by me are 20 or 25 series on a 24" wheel.. anyway lets all move past the wheels they will soon be gone
  8. Lol.. Sorry just keeping the 4"sfd lift.. So my question is with a four inch subframe drop lift the biggest tire i can fit are 33 s just curiouse because sliverpathy was running 33's with just the 2" ac coils... So i think im going to pick up a set of 33's
  9. thanks for that response... i was on the fence with the extra 2"... but after ur post im most likely not going to do it... ill keep the 4"sfd and some 33"tires... that the safest i can go correct?
  10. what did that run you $$ is it still possible to have another set made? how does your truck drive handle compared to stock... mine is driving like ass (not from the sfd) the rear 4 link bushings are shot and the rear axle is all over the place during breaking and accel... really wanna try two more inches of lift but im a bit worried.. does the steering have to be extended even more (after sfd extension) thanks
  11. you guys with the ac coils and the sfd what are you running as a rear coils?
  12. wj 3 inch lift coils...150 for the set
  13. totally shocked i can fit such a big tire.... i have 2" spacers tht i bought like a year ago...tried to fit titan 5 spoke wheels... so im sure the bs will be no problem... anyone running 35's on just the sfd?
  14. just picked up a set of 4 poly split kit from atomotive customizers..... and the bolt kit just in case.. isnt there a how to on replacings them... easy enough to do just time consuming..... any tips tho.. im thinking... A map torch-burn the old bushing apart and drill the old bushing apart to remove the center then press the old bushing sleeve out..
  15. so what would i need for an r50 with 4" sfd to run a 35" tire what rims specs
  16. were can i get a set of upper and lower links for the rear of my r50 hopefully with the bushings in them.. my uppers need to be replaced and 1 of my lowes has a bend in it... so im just gonna replace all of em.. any ideas were i can get a set
  17. so this is the first off road trip i have taken with my r50...ive wheeled many yj's and my raptor atv's but i had an awesome time even with the ****** tires on the truck check it out
  18. so could i fit 315/75/16 total of 34.5 diameter on a 4" sfd lift http://www.treadwright.com/shopnow/entity/tabid/60/entityname/category/categoryid/40/sename/31575r16.aspx
  19. mine has been lifted for a week and im in the same boat... want some more highness...
  20. wish i had a press.. i would do exactly what u did
