Elkman
About Elkman
  • Birthday 08/17/1940
    1995, 5 Spd, 4D, 4x4, Silver. Bone Stock
    Rarely Go Off-Road
Contact Methods
  • Website URL
    http://
  • ICQ
    Ardmore, Ok
1,957 profile views
Elkman's Achievements
  1. Elkman
    Goo
    I have had some success with a solvent called Xylol and WD-40.
  2. There have been several posts in the past on oil filter relocation kits. There is even a link to Summit Racing to a part # SUM-G4985, but it does not show that it fits a 1995 model. Is there something else to buy to make the kit fit or is it complete as ordered?
  3. You know, I never considered the simple solution. I was having trouble with my cruise and I removed and cleaned the switch and it has been working perfect since. Thanks
  4. The AC on my 95 worked fine until a couple of weeks ago then just quit. The light does not come on when you press the AC on/off button. I have checked the main fuse, but there must be another one on or around the compressor. Can anyone help me? Thanks
  5. Glad to see your email. I couldn't figure out why I couldn't get into the website. I was missing the discussions. Keep me posted.
  6. When I bought my 95 Pathfinder a couple of weeks ago, the seller said the cruise worked, but doesn't. The switch on the dash lights up when turned on, but nothing happens when I touch the set on the steering wheel. Is there a fuse somewhere I need to check? All the fuses under the dash are good. Thanks
  7. In the owner's manual for my '95, it shows that the standard tire size is 235-75's with the option for 31-10.5. I would like to change to the smaller "and cheaper" tires, but what will that do to my speed-o-meter? What do they do at the factory, change the speed-o-meter gear? If so, does anyone know the part #. I'm new to your forum having just purchased my Pathfinder. Can use your help.
