hickory
    1998 SE
    Screwdriver Mechanic
    trenton, ontario
hickory's Achievements
  1. Yes I did thanks. The drums had not been off for a while and took a fair amount of time turning the adjuster wheel bakwards through the inspection hole on the back of the drum. I ground the lip off of the drums so I could fit the drums on almost snugly while sdjusting the adjuster. The LSV is also djusted throiugh the plate attached to the diff but still not in 194 mm range should be. Thnaks for the reply
  2. My 98 pathfinder rear anti lock are not working properly,read the codes nothing stored, replaced raer wheel cylinder and spring kit, bled the system, rears still locking up. any Ideas
